Sponsored by: Real Truck
windows out, door locks control lights... GEM issue, emergency on leave!
Old Jul 3, 2011 | 05:42 PM
NavyMIDN08's Avatar
NavyMIDN08
Was working to get my lights fixed while I was home on leave. Got most of the electrical gremlins fixed, and went to start it, and I've got some other issue.
When I hit my lock button, the interior light comes on, and the door chime sounds. windows dont work, wipers don't work, and the engine isn't running. Is this my GEM out? There is a clicking sound coming from under the dash. I need to get this fixed, like right now, or I'm going to be taking a bus back home, and I'm in a world of hurt.
Truck is a 1999 F350 with a 12V cummins swap. I don't know if the GEM going out would affect the engine or not. It
Old Jul 3, 2011 | 08:03 PM
F350-6's Avatar
F350-6
I have no idea if the GEM would affect your motor either, but you should be fine to drive it with a faulty GEM. Can you locate the clicking under the dash? Is it the GEM or maybe just a relay? Is your battery voltage good?
Old Jul 3, 2011 | 10:34 PM
NavyMIDN08's Avatar
NavyMIDN08
battery voltage is good. Figured out that the running problem was the fuel shutoff solenoid sticking. the alternator is running through a ford regulator, and is wired in separately. still have all the window/wiper/locks issues.
I'm willing to drive the truck home, but I haven't figured out the AC system yet (PO really screwed me on this one...), and without windows open I'll cook alive. I'm guessing that I'll have to roll them down with a battery and leave them that way, and pray I don't get rain...
Old Jul 11, 2011 | 08:26 PM
NavyMIDN08's Avatar
NavyMIDN08
Well, here's my update, and plea for help.
I don't know who to PM on this issue, if you do, PM them for me please
I made it home. Rolled the passenger side windows down using a length of wire attached to the battery. had no wipers for the drive home. Not sure what else I did wrong. My radio is on unless I disconnect the battery.
I'm at my wits end. From reading previous posts it seems like my GEM is fried, which would make sense (I crossed the wrong wire and smoke came from behind the fuse panel...). I fried part of the engine harness and had to wire the shutoff solenoid on the cummins open for the truck to run. This happened after the windows/wipers issue reared its head.
Can a stealership test my GEM and confirm thats the issue? since I don't need the GEM to control engine functions (12V Cummins...), can I use any GEM off of any truck to get my wipers and windows back, along with my other functions? I still have my gauges, are these routed through the GEM?
I've searched, and yet I can't find answers, someone please help me. This truck has turned into a friggin' money pit and I can no longer afford to fix it...
HELP ME PLEASE!!!
Old Jul 11, 2011 | 08:32 PM
Quad Racer's Avatar
Quad Racer
Man I'm sorry I can't offer any help, only well wishes, but I did want to take the time to thank you for your service. Good luck on this.
Old Jul 12, 2011 | 05:54 PM
NavyMIDN08's Avatar
NavyMIDN08
anyone know? someone here has to know what the GEM controls...
Old Jul 12, 2011 | 06:41 PM
brd7666's Avatar
brd7666
Maybe this will help.
Old Jul 13, 2011 | 08:47 AM
NavyMIDN08's Avatar
NavyMIDN08
Definately what I was looking for. I'll call my local JY and see what a GEM costs. hopefully they can track one down for me.
Do I need to find a special one with my same features, or will any one work?
Old Jul 13, 2011 | 05:25 PM
brd7666's Avatar
brd7666
You will need the one for your truck. There might be more then one for your year. I changed one on our 99 Taurus not long ago. I pulled it out first, and got the part number. The Ford dealer wanted over 325 bucks for one. I went to a salvage yard and got one for 20 bucks. I had to pull 4 of them before I found the right one.
Old Jul 13, 2011 | 06:34 PM
NavyMIDN08's Avatar
NavyMIDN08
my local salvage yard says 75-80, but I need to take mine in to get matched. I think there may be a pull-apart somewhere south of here, but frankly the ease may be worth the mullah this time
cekkk
Electrical Systems/Wiring
Jun 3, 2012 06:58 AM
jgfan24
Aug 5, 2011 10:19 AM
Macon SCrew
1997 - 2003 F150
Jan 19, 2011 09:37 PM
babstinger
Sep 6, 2010 06:44 PM
Welkmeister
Mar 2, 2010 07:15 AM
