No 2nd gear C6
Old Dec 24, 2010 | 08:03 PM
duck fan's Avatar
duck fan
Because racetruck
No 2nd gear C6
I picked up an 89 F250 with a 5.8 and a C6. The price was beyond good. When I drove it home I thought at the time it only had 1st and 2nd gear. I was only able to manage 35mph. I have since figured out that it was only 1st but slippy. To top it off, I didn't have much in the way of brakes.
After doing plenty of searching here, I replaced the Vacuum modulator and cleaned up some vacuum leaks. Now I have 1st and 3rd and I also got the brakes back. I discovered today that the trans never goes into 2nd gear. Even if I put the gear selector in 2nd, all I get is 1st. Additionally, When accelerating, it will hold 1st gear unless I let off the throttle, then it will engage 3rd.
It goes into gear fine, reverse too. Your help is much appreciated.
Old Dec 25, 2010 | 05:48 AM
stuart1's Avatar
stuart1
The intemediate band is the culprit.
It can be adjusted externally but before doing so drop the pan and see if the struts are in position.
The lining is very thin and if worn out you will have metal to metal contact with the drum.
If the band is worn or broken there is a "snap" version that can be installed without removing the transmission.
Old Dec 26, 2010 | 08:09 PM
duck fan's Avatar
duck fan
Because racetruck
I've done a little reading on the snap band. Where can I hunt one down should I need to?
Old Dec 26, 2010 | 10:10 PM
stuart1's Avatar
stuart1
Any transmission shop should be able to get one but if not Ford did sell them but whether they still have any is another question.
Ford #
D9AZ-7D034-BMF
Romulus
Jul 16, 2018 10:10 AM
xxsocomxx
Jun 4, 2017 10:47 AM
Ford-N-floored
2015 - 2020 F150
Nov 27, 2015 09:37 PM
racinmike88
Oct 18, 2010 10:55 PM
79f100six
Oct 8, 2010 01:04 PM
