Check coolant additive warning?
Old Nov 4, 2010 | 11:19 AM
rocdril's Avatar
rocdril
Anyone get this warning on the dash after startup? I checked my coolant level, it was right on the fill line, went to Ford anyways and got a gallon of the "orange anti frezee", put some in.
Now I cant get rid of the warning, eveytime I start the truck its there. I tried reading the manual, if its in there I missed it.
Thanks for any help in advance.
Old Nov 4, 2010 | 11:49 AM
djjoshuad's Avatar
djjoshuad
you need to be sure you are using the right coolant, and you need test strips SPECIFIC to the OAT coolant. there are many threads about this.
Old Nov 4, 2010 | 12:02 PM
rocdril's Avatar
rocdril
I actually tried a search, but it was for the warning, maybe I should search for the coolant.
The Ford parts guy looked up the coolant so he was sure he gave me the right one.
Should I have to be testing my coolant with only 13,000 miles on the truck?
Old Nov 4, 2010 | 01:23 PM
djjoshuad's Avatar
djjoshuad
in a perfect world, no... but better to be safe than sorry. At 13k I'd tend to blame the sensor, but using a test strip is the only way to know for sure. If it tests ok, get the dealer to fix it under warranty. If it doesn't, you just need to put in some additive (not a whole gallon of new coolant).
Old Nov 4, 2010 | 04:10 PM
ruschejj's Avatar
ruschejj
The truck is programmed to inform us that we need to check the pH level of the coolant at specific mileage intervals. Most will see the message at or before 15K miles.
There is a test kit available from Ford parts dept. specifically for the '11 and up 6.7 diesel engines.
Old Nov 4, 2010 | 07:31 PM
rickatic's Avatar
rickatic
I have been down this road. It is a suggestion for using the test strips for ph testing etc. If you go to the information screen and scroll through the menus you will find the page for turning the warning off. BTDT
blkmesamtman
2009 - 2014 F150
Jun 10, 2017 08:50 PM
southwindva
Mar 10, 2017 05:44 PM
Dandman1
6.7L Power Stroke Diesel
Sep 5, 2014 04:29 PM
my996duc1
Apr 10, 2012 10:03 PM
