Fuel Pressure Reg Spring Kit
Old Oct 14, 2010 | 08:17 AM
lawnboy1965's Avatar
lawnboy1965
What do you gain by putting this kit in, besides the obvious, (more fuel pressure)?
Old Oct 14, 2010 | 08:34 AM
69cj's Avatar
69cj
You just answered your own question. The factory spring can be borderline and this upgrade gives your injectors some breathing room. App. 10 to 15lbs. worth.
Old Oct 14, 2010 | 09:04 AM
lawnboy1965
I will be ordering it today, hopefully it will be here tomorrow or even better yet, they have it on hand. Yea right.
Old Oct 14, 2010 | 09:34 AM
joe blow's Avatar
joe blow
If you are patient, order it from edpartsguy.com
The cheapest I found unless you have a hookup at the FORD stealership
Old Oct 14, 2010 | 10:15 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
i'll hook you up.....
Old Oct 14, 2010 | 10:17 AM
lawnboy1965
Ed, if the dealership didnt have the part on hand I would order it from you. I have a great hook up at the dealership and he gives me great prices. I will be installing it this weekend.
Old Oct 14, 2010 | 10:31 AM
dchamberlain's Avatar
dchamberlain
The black piece goes in depending on the year. On my late build '04, the black piece was in there. On the '05 upper fuel bowl/oil filter housing that I bought to replace mine when I broke it, the hole was already machined for the poppet valve.
Old Oct 14, 2010 | 10:35 AM
Parts Guy Wyatt
Former Vendor
no worries, throw me a bone when you can....
Old Oct 14, 2010 | 10:50 AM
lawnboy1965
I dont have a problem doing that what so ever.
Old Oct 14, 2010 | 10:51 AM
olfordsnstone's Avatar
olfordsnstone
Is the installation of this kit difficult? Where is it and how long of a job is it? This is the first I have caught discussion on this upgrade.
Old Oct 14, 2010 | 10:57 AM
Strokin-8's Avatar
Strokin-8
Doesnt take long 30 min max. The hardest part is getting to the lower bolts due to coolant hose in front. Simple task.
Old Oct 14, 2010 | 01:13 PM
davidkstyler's Avatar
davidkstyler
I have a cracked fuel filter bowl. I overtightened my fuel pressure guage sender.
I have a new housing and spring kit on hand, how hard was it to replace the housing? Anything to watch for? Going to replace it this weekend.
Old Oct 14, 2010 | 01:20 PM
  #28
F 250 6 liter's Avatar
F 250 6 liter
What does this kit do? How hard to install? I have a tuner and I am not getting enough fuel to it.
Old Oct 14, 2010 | 01:30 PM
  #29
dchamberlain
You can read my experience here.
https://www.ford-trucks.com/forums/9...stupidity.html
I found a good write up on how to do it posted by m-chan on the Diesel Stop forums.
6.0L Secondary Fuel/Oil Filter Housing 4C3Z-9C166-AA - Diesel Forum - TheDieselStop.com
You will need to disconnect as many of the plugs on the upper engine as possible. Both plugs to the fan and the plugs to the ECT, EOT and oil pressure switch, etc. Then you have to very carefully lift the wiring harness up over the oil stand pipe, because it goes between the oil filter housing and the fuel filter housing. Be very careful. The stand pipe will break easily, so I'm told.
Old Oct 14, 2010 | 01:50 PM
  #30
Headviking's Avatar
Headviking
Partsguy. I like to use Paypal instead of my CC. Can I use PayPal instead for my order?
