power cowl vent
Old Oct 8, 2010 | 08:54 PM
arrowheadfred's Avatar
arrowheadfred
power cowl vent
Has anyone put a power cowl vent on there truck ? The motor has a arm on it to replace the handle.This handle is braded on . So do i cut the handle and drill a hole or do i cut the brad. I hope someone understands what i'm trying to say here.
Old Oct 8, 2010 | 09:10 PM
Julies Cool F1's Avatar
Julies Cool F1
Here's a previous thread on the power vents. I think it names some names of folks who have put some in:
https://www.ford-trucks.com/forums/2...cowl-vent.html
https://www.ford-trucks.com/forums/8...cowl-vent.html
Power Cowl Vent
https://www.ford-trucks.com/forums/9...ent-power.html
Looks like Sam (sdetwiel) is the guy you want to talk to!
Old Oct 8, 2010 | 09:33 PM
fifty-two_f1's Avatar
fifty-two_f1
Has anyone figured out the trick to make their cowl vent not leak when going through a rainstorm??? I have been deviled by this for a long time. I have a new seal (installed properly) and adjusted multiple times and cannot win
Old Oct 8, 2010 | 09:34 PM
leverhead's Avatar
leverhead
I installed the power cowl vent motor from Rocky Hinge. The arm from the motor is attached to a metal strap I made and tacked onto the bottom of the cowl vent....the strap spans the distance of the bottom opening of the cowl vent from front to back (maybe a couple inches long). Other than that, it is mounted under the cowl vent inside the cab on a horizontal bracket I made that is welded to the firewall, spans the vent opening then goes up 90deg to the lip of the vent opening and is tacked there. Hope this helps. Regards.
Old Oct 8, 2010 | 10:29 PM
sdetweil's Avatar
sdetweil
we need a different gasket when we use the power vent.. mine doesn't close all the way either.. and its a new gasket from MF.
the manual arm worked fine, but the dash extension is in the way..
Sam
Old Oct 8, 2010 | 10:59 PM
arrowheadfred
WET FLOOR NO WAY
So whats the trouble sam? Is the gasket to thick and the motor too weak?
Old Oct 8, 2010 | 11:07 PM
Mervy49's Avatar
Mervy49
ignore my above comment, there are better posts here that appear after I posted. sorry folks.
Last edited by Mervy49; Oct 8, 2010 at 11:16 PM. Reason: information is incomplete
Old Oct 8, 2010 | 11:33 PM
sdetweil's Avatar
sdetweil
the motor does not apply the same amount of torque that a human can on the manual lever..
Sam
Old Oct 8, 2010 | 11:37 PM
52 Merc's Avatar
52 Merc
Yeah, weld the dopey thing shut.
There's a reason the factories went away from having an open door scooping the elements onto the floor of the cabin.
Old Oct 8, 2010 | 11:52 PM
arrowheadfred
weld it up
I was thinking about boxing it in under the dash and making a air induction system out of it. But if i close it when it rains and then it leaks and puts water in my carb.That would suck.Guess i could build a trap to drain any water off.
Old Oct 9, 2010 | 12:31 PM
Julies Cool F1
You can fix the water problem by making sure the vent is adjusted flat when it's closed, and also not using the aftermarket cowl vent seals being sold. Buy a softer piece of rubber seal or tube that will compress easier - allowing the vent lid to come in contact all the way around and seal.
It also helps alot of the underside of the vent lid is not rusted or pitted and makes a smooth seal.
By soft, I mean something similar to the sponge rubber fender to cowl welt (the thick one) used on 51-52 F-Series.
Old Oct 9, 2010 | 04:24 PM
sdetweil's Avatar
sdetweil
thanks.. I'll see if I can find something..
my cowl is perfect, painted both sides, and I am using the new cowl gasket..
I just put the hollow core door gaskets on the 55, and altho I hate gluing things on they are superb!.. doors close easier and seal better I think..
Sam
Old Oct 9, 2010 | 06:27 PM
dongc1's Avatar
dongc1
Sam
Does this mean that you are going to start driving it in the rain ????LOL.
Old Oct 9, 2010 | 06:43 PM
Julies Cool F1
I found the aftermarket seals to be way too stiff. As the cover comes down it's at an angle and hits the back part of the seal first.
Then the back part of the seal flattens out as the cover comes down (and levels out) the rest of the way and contacts the front surface of the seal - in theory.
If it's too stiff, the cover can't compress the back part of the seal enough to come down enough to seal in the front.
Old Oct 9, 2010 | 08:33 PM
sdetweil's Avatar
sdetweil
now, don't go start pushin me!
I gotta fiddle with it
Sam
