power cowl vent
Old Sep 20, 2004 | 02:47 AM
52 panel's Avatar
52 panel
power cowl vent
Hope one of you all can point me in the right direction. I have a 52 f-1 panel and want to install an electric motor to operate the cowl vent. I live in Pensacola, FL and it do get hot here. I love the air flow the cowl vent gives me. Right now, no a/c so the air flow is appreciated. I intend to put air in it and will be building an dash extention to house the a/c vents and controls. By putting the motor on the cowl vent, it will be much easier to operate with the additonal dash obstruction. I have seen a unit advertised to make the adaptation but for the life of me can not locate it again. Does anyone out there know the answer?
52 panel
Old Sep 20, 2004 | 08:42 AM
LEckart's Avatar
LEckart
Welcome 52 panel -
Try Rocky Hinge Company, www.rockyhinge.com. They have one, OCV 01, for $80. I bought mine from Ball's Hot Rods but I don't think they are in business any longer. I have purchased other items from Rocky Hinge and the quality was always good. 56FUN
Old Sep 20, 2004 | 01:09 PM
Jag Red 54's Avatar
Jag Red 54
I bought the kit from Sac Vintage ford for my 54. I believe it was about $150 complete with brackets and prewired switch. It works well and the install was only complicated by the fact that I installed the A/C system first! The motorized cowl vent should be done first, then the A/C unit. Good luck, John
Old Sep 21, 2004 | 09:59 AM
Scott123's Avatar
Scott123
I got one from the last of the stock at Ball's, but found the same one in a catalog from Yearwood. It's around $60, but it is also univeral, for cowl vents, trunks, glove box doors, etc, so you have to do your own engineering to hook it up right.
Scott
Old Sep 21, 2004 | 10:11 AM
learpilot's Avatar
learpilot
Will a power window motor work or is it too weak?
Old Sep 21, 2004 | 11:41 AM
Jag Red 54's Avatar
Jag Red 54
If you engineer it right, then I think an electric window motor would do. However, that seems like a lot of work to accomplish in a very cramped space. Good luck with it and let us know your progress. Future readers will need to know also. John
abe
Jul 2, 2021 12:21 PM
augsburger
Feb 8, 2017 09:38 AM
Torky2
1978 - 1996 Big Bronco
Nov 16, 2016 11:21 PM
jvmcc
Jun 11, 2016 06:22 PM
parr4
Paint & Bodywork
Oct 5, 2002 12:07 PM
