Need To fix Heat
Old Oct 6, 2010 | 04:04 PM
2000-EB-EXPY-AWD's Avatar
2000-EB-EXPY-AWD
Question Need To fix Heat
I just tried the heat in my 2000 Expy, and the front blows hot, but not like I think it should, and the back blows ice cold. It has the front and rear heat and a/c system. Everything else seems to work fine.
Has anyone had any expierience with this prob? Since my 4 kids will be riding back there, one of them being a newborn, I need to figure this thing out ASAP.
As usall, any and all help would be greatly appriciated!
Old Oct 6, 2010 | 04:17 PM
alloro's Avatar
alloro
It could just be that the blend door isn't moving over to the hot side when you turn the temperature dial. I'd first check for that operation before getting into anything else.
Old Oct 6, 2010 | 05:57 PM
2000-EB-EXPY-AWD
Thanks for the responce!
Is the front and back two seperate systems? I know there is a seperate a/c system for the rear, but is it a full system with its own core and blend doors, etc... A/C stuff is all above back passenger side wheel well, is the rest of the rear system in there too??
Old Oct 6, 2010 | 06:07 PM
alloro's Avatar
alloro
Is the front and back two separate systems?
Yes they are. separate heater cores, separate blend doors, and separate controls. About the only thing they share is the coolant circulating from the engine.
Old Oct 6, 2010 | 09:39 PM
kailor's Avatar
kailor
I would check to see if antifreeze level is sufficient and radiator cap is tight.
Never mind...you stated that the front blows hot.
Old Oct 7, 2010 | 10:55 AM
dirtmonkey11's Avatar
dirtmonkey11
It either sounds like the blend door for the rear isn't working, or the heater core for the rear is plugged.
vwbuge
May 31, 2012 04:44 PM
rhu05
Dec 22, 2010 05:04 AM
dfisherman
19
Jan 3, 2010 03:00 PM
bingo begone
27
Jan 25, 2009 06:07 AM
kanuhackett
Feb 10, 2007 07:07 PM
