Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
My project
Old Mar 8, 2016 | 04:42 AM
  #31
Spirit of '76's Avatar
Spirit of '76
I'll take a look bigcrunch, when I get a chance, the truck is put away for the winter and it will be a bit of work to get at it. If I recall correctly, you need more than just the booster/ MC. I'm pretty sure you also need the pedal assembly and firewall plate? I'll have to look. Maybe Bill (or someone else) will chime in on this? I think it was Bill (ND) that gave me the idea in the first place.
Old Mar 8, 2016 | 09:12 AM
  #32
firebirdparts's Avatar
firebirdparts
Interesting brakes (single piston). They work more (a lot more) going forward than they do backward. I don't have a truck this size, but I have had the pleasuring of single piston drum brakes.
Old Mar 8, 2016 | 05:54 PM
  #33
Spirit of '76
Yeah firebirdparts, interesting is one way to put it, as I have yet to complete this projects and road test it I sure hope it doesn't become to interesting!
Old Mar 10, 2016 | 07:38 PM
  #34
firebirdparts
I would imagine the rears are bi-directional. If they're not, then you'd never be able to stop it rolling down a hill backward with a load.
Old Mar 10, 2016 | 09:01 PM
  #35
Spirit of '76
Yup, duel cylinders, duel pistons.
Old Mar 14, 2016 | 06:57 PM
  #36
Spirit of '76
Well, I actually did. With plenty of wood for the wood stove and ample liquid refreshments, I got almost all of the wiring complete! Including this B- bus bar with many independent grounds;
Blue Sea Systems 150 Amp Common BusBar
a B+ bus bar for additional circuits, 3 maxi fuses, one to protect the wiring harness, one for (point of future edit) and one for future reference. I took the radiator to a local shop to have two bungs brazed into the tanks. One in the bottom tank so I could plumb this tank style engine pre heater into the cooling system(I actually got mine at JC Whitney years prior and it had been sitting on a shelf unused, can’t find it on their site now);
Zerostart-Zerostart Heavy-Duty 2250 Watt Industrial Heater - 3305004-3305004
And one in the top tank for the temperature probe for this electric fan;
Flex-a-lite Low Boy Electric Fans 118 - Free Shipping on Orders Over $99 at Summit Racing
And this fan controller;
Flex-a-lite Variable Speed Controllers 31163 - Free Shipping on Orders Over $99 at Summit Racing
Old Mar 14, 2016 | 07:00 PM
  #37
Spirit of '76
I also installed one of these engine pre oilers;
Canton Racing Accusump Oil Accumulators 24-046 - Free Shipping on Orders Over $99 at Summit Racing
Along with this valve (this actually looks like a newer model);
http://www.summitracing.com/parts/ctr-24270x
and this check valve;
http://www.summitracing.com/parts/ctr-24-280
These mounting brackets;
http://www.summitracing.com/parts/ctr-24-240
And this adapter;
http://www.summitracing.com/parts/ctr-22-565
Relays like this for headlights;
40 Amp Automotive Relay with Metal Tab - Wiring Products
And auto reset circuit breakers like this;
30 Amp 'Short Stop' Auto reset Circuit Breaker 12 Volt Right Angle - Wiring Products
With these covers;
Standard Circuit Breaker Boot - Yellow - Wiring Products
With lots of these connectors;
22-10 Gauge Non-Insulated Butt Splices - Wiring Products
and lots of heat shrink tubing that I picked up at my local Ace hardware store and lots of pre tinned marine grade wire. Also got an alarm at a local auto accessory shop and wired that in along the way.
Old Mar 18, 2016 | 05:47 PM
  #38
Spirit of '76
So it was a good winter . Made a lot of progress and emerged from the shelter in the spring of 2011 with a running truck! No brakes or exhaust, but a running truck!
Old Jan 2, 2017 | 08:59 PM
  #39
Bobird's Avatar
Bobird
�� very cool!
Old Jan 14, 2017 | 06:06 PM
  #40
Bobird's Avatar
Bobird
Originally Posted by Bobird
�� very cool!
did you source new cab mounts bushings and bolts? I'm looking for some replacements.
Old Jan 16, 2017 | 06:03 AM
  #41
Spirit of '76
My bushings were all in usable condition and I used SS bolts that I picked up locally.
eazmo
Dec 4, 2020 08:53 PM
Spirit of '76
Large Truck
40
Nov 14, 2019 04:51 AM
Curated Content Editor
General Automotive Discussion
Dec 9, 2016 12:33 PM
Mr. Ed
Aug 27, 2016 09:46 AM
Mr. Ed
May 20, 2016 08:36 AM
