what year is my 460?
Bought a 72 ford shortbed 4x4 with a 460 in it.This is my first ford.Is there some way of detirmining the year.Some of the numbers i found on the intake are as follows,at the back of the intake were the numbers 7 B 10 at the front of the intake above the firing order were D6VE-9425.Some of the numbers i found on the head are as follows,outside of the head below the valve cover are D3VE-A2A and on the inside of the head under the valve cover are 7 A 18.Did not see no numbers on the block.It has a factory 4-barrel intake and carb.The truck also has an electronic ignition in it.The carb spacer has the place for an EGR valve,but has a plate on it instead.It uses the 5/8 spark plugs.That is all i can think of at the moment.
Just a quick refresher.
When a part has a basic cast IDent number it does NOT make it that year of cast.The Actual cast date in in a 3 digit casting near the part ident number.
In other words you can have a part like an intake manifold with a D3AE-9425-AA number but it has a *5C28 *cast date.
These characters here ( D3AE ) only mean the part was designed in that year for a certain engine/vehicle.
In this case a 1973 Large Ford Car possibly an LTD,but used on other vehicles.
The Date is in this other number.
See example below.
See example below.
Yes, This (D2VE-A2A) is the basic design number with the
change-up code (A2A) of the part.
The actual casting date code is cast into the oil galley part of the head itself take the valve cover off to see it.
If it was (D2VE-A),this would mean it was the very first design of this part.
A simple little thing like a hole being cast for something more, the part would be cast as (D2VE-B) and so on.the more things on that particular part that change the suffix letter goes further along the alphabet to a certain letter then they add a letter or number ie : A or 2 .
Also remember,this is NOT the part number in Ford's Part Numbering system,it is a cast ID number.
webslinger67
10-14-2013 03:47 PM
junkyarddog82
08-25-2009 01:53 PM
scottfreeman
17
08-18-2008 11:49 PM
tn.countrygirl
General Automotive Discussion
15
07-13-2007 01:48 PM
