E40D to zf..
Old Oct 3, 2010 | 11:07 PM
Krisx125's Avatar
Krisx125
E40D to zf..
Hey guys, i picked up a 1993 Extended cab F-250 7.3 4X4 to swap the zf into my 1997 F-250 Ext cab. Ever since the truck has been sitting at my shop my auto is slipping worse and worse everytime i drive it. So im going to start the swap here soon...First im going to gut the donor truck and blast the drive shafts and paint them. And clean everything..little at a time. When i do this project what extra will i need...Do i take the wiring harness for the zf out of the parts truck? I cant seem to find the write up for this project.
Old Oct 3, 2010 | 11:15 PM
cowmilker08's Avatar
cowmilker08
I know you will at the minimum you have to have the PCM reflashed. Manuals fuel different than automatics. You truck will run and drive after the swap without reprogramming, but you won't even want to drive it.
Old Oct 4, 2010 | 07:47 AM
Brown Falcon's Avatar
Brown Falcon
You can use the auto PCM with a manual trans with no problems. You don't HAVE to reflash it, but I would get a chip for a manual later anyways.
Redman84 did this swap and did a really good writeup on it a few months ago. I'll try to find it for you. Send him a PM, he had lots of info and knows how to do all the wiring so it all works right.
Old Oct 4, 2010 | 07:52 AM
Brown Falcon
Old Oct 4, 2010 | 10:19 AM
Krisx125's Avatar
Krisx125
Thank you!
Old Oct 4, 2010 | 03:31 PM
rideracelivemx7's Avatar
rideracelivemx7
when are we doing this swap you sally!!!!!! and i said screw the harness! just cut out cleanly and professionally what we don't need!
Old Oct 4, 2010 | 04:08 PM
redman84's Avatar
redman84
Here you go. I think this one may be pretty useful. You may remember it. After all, it is your thread... And with both of our swaps being from and extended cab to extended cab the driveshaft issues should be similar. Is your truck 2 or 4wd?
https://www.ford-trucks.com/forums/9...peed-swap.html
Also, here's one I put up on PSN. I thought I put it up here too but can't find it. It addresses cruise control problems after the swap.
Trans swappers READ-cruise control fixed - Powerstroke Nation
You can run the auto PCM after your swap too. I had the choice of running a manual PCM and not having cruise or running my auto and having cruise. I chose the one with CC. Soon enough I'll get it reburned or get a chip but until then...
Old Oct 4, 2010 | 08:33 PM
Krisx125's Avatar
Krisx125
yep. wapping the tranny stuff from a 1993 F-250 7.3 EXT cab 4X4 to a 1997 Ext F-250 7.3 4X4
Old Oct 4, 2010 | 09:40 PM
Krisx125's Avatar
Krisx125
ASAP!!!!!!!!!!!!!!!!!!!!!!!
Ford4Life7.3
Sep 15, 2014 12:01 AM
FordOwnerJoey
Feb 3, 2014 07:47 AM
wgerson
Sep 22, 2013 11:53 AM
crazed87bronco
52
Mar 29, 2011 02:53 PM
Mr Man
Nov 1, 2004 07:05 AM
