Good Buy?!?
Old Oct 4, 2010 | 07:31 PM
court1100f's Avatar
court1100f
as for the transmission I'd get the Transmission serviced probly about 80 dollars thats what it'd be here in Houston,Tx and they'll completely drain the transmission both the pan and torque converter aswell as replace the Filter I BET that resolves the problem by it'self. with it being an E4OD it could also possibly be a sensor or electrical connection to the coil packs. BUT get it up to normal running temperature and park on a level surface throw it in park and Check your transmission fluid for any Metalic glitter or debree and also level ofcourse but more of interest is the health of the fluid is it burnt is it discolored or does it still look new???............barring that I've heard these transmissions can be had at a junk yard for about 350-500 depending on where you go Hope that helps
Old Oct 4, 2010 | 07:47 PM
94F15094's Avatar
94F15094
hey court thanks a lot man. Im thinking Im gonna buy it off him
94F15094's Avatar
94F15094
Thank you aswell Ranger
Old Oct 4, 2010 | 08:02 PM
court1100f's Avatar
court1100f
your Quite welcome my Friend Glad I could help that 300s one of the most indestructable engines ever produced
Old Oct 4, 2010 | 08:04 PM
94F15094's Avatar
94F15094
Ill post some pictures after I pick it up.
Old Oct 4, 2010 | 08:33 PM
court1100f's Avatar
court1100f
Awsome Sounds good to me!!!! by the way Whats your name lol??? YOU have ME at a slight disadvantage in that regard Congratz on the decision to get the truck
Old Oct 5, 2010 | 10:02 AM
94F15094's Avatar
94F15094
The names Brandon... Thanks again
Old Oct 5, 2010 | 11:08 AM
lupin398's Avatar
lupin398
I have probably the same truck and If you have an E4OD/300-6 combo with 3.55 gearing, you can achieve 17-23MPG depending on constant highway/etc. conditions. I know I got at least 23MPG or better driving for about 1,000 miles. 98% was strict highway driving without a stop sign or red light to be had as far as the eye could see.
Right now driving about 34 miles a day back and forth to work, I'm getting about 17-18mpg steady.
lupin398's Avatar
lupin398
fernfly
May 16, 2012 05:11 PM
lilreb8610
1997 - 2003 F150
Apr 1, 2010 02:08 PM
f100andf150
Arkansas Chapter
Jun 6, 2006 08:56 AM
70f100longbed
3.8 & 4.2L V6
Jan 4, 2003 07:51 PM
Darkstar
Dec 7, 2002 04:28 PM
