trouble code help
Old Oct 23, 2010 | 03:45 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Are these continuous memory or active key on engine running?
Or some of each?
Any active Key on engine off?
Did you check that the SPOUT plug is in place?
Old Oct 23, 2010 | 04:51 PM
oreocreaming's Avatar
oreocreaming
these came up after driving the truck. i check the codes key on, engine off. not sure what spout plug is.
Old Oct 23, 2010 | 05:07 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Judging from you current situation, it's time you looked for yours! See link: spout
The Plug is removed when base timing is checked or adjusted. Forgetting replacement of the Gray plug after timing adjustments occurs frequently.
More diabolical, it is "intentionally" removed & left out, to hide a "Ping under load problem" from an unsuspecting buyer. This is because your timing will remain static, w/ no ECU advance w/o the plug in place.
What does your timing read?
Duckman77
May 13, 2013 08:37 PM
siboriqua
1983 - 2012 Ranger & B-Series
May 1, 2012 10:48 PM
samcarpen
Mar 5, 2010 10:20 AM
SZAlbNM
Jul 13, 2006 11:18 AM
01silvergt
Jul 13, 2005 02:08 PM
