I have a 51 F1 when I hit a bump in the road the front end shimmys and bounces up and down, I have to stop to get it to stop shimming. Not much fun at 60 mph. I have installed new king pins, shackle pins, shocks, wheel bearings, but it will still shimmy, What am I missing. I do not have stock wheels on it have heard over size wheels will make it do this. I dont see any play in my drag link. Your help is appricated. Will a steering dampner help?
Thanks Don
I know you went through the frontend on your truck, but I thought I did too, and had loose steering problems. Just by chance I took the u-bolts loose that held the axle in, and then I grabbed the spring pack and forced it in and out and found lots of movement on the driver's side pack. The passenger side was tight. I got to looking and the rear spring hanger that was riveted to the frame was wore out. Even though a new pin was installed, I didn't notice the hole in the bracket had wear. I replaced this hanger bracket, went and got it aligned, and it really made a difference.
I went through the truck front to back yesterday. U bolts on rear axel were a little loose, retighten the front u bolts and readjusted the drag link. Everything is tight I ordered a steering dampner . Hopefully this will take care of it.
I had this problem a number of years ago and took it to a shop where they knew what they were doing. Unfortunately, I forgot what they did.... seems like they said they added shims to some part of the steering, and it was still pretty loose but the shimmies were gone forever. I know this is incredibly vague, but maybe I can jog someone else's memory...
