6.0 Cooler!
Old Oct 4, 2010 | 09:55 PM
cps's Avatar
cps
I just added a Truecool cooler in line with the stock one and that did the trick. It was only 120$ and simple to add on. Temp never get over 140 driving empty.Lots of other people have done it this way with similar results.
Old Oct 5, 2010 | 12:24 AM
big poppa's Avatar
big poppa
Just did what CPS mentioned above too, added a Derale 7000 trans cooler inline with my stock one, under a hundred bucks. Clay at RiffRaff should be selling them soon.
Old Oct 5, 2010 | 01:18 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Riffraff Diesel: Derale 20,500 GVW Transmission Oil Cooler
Old Oct 5, 2010 | 07:34 AM
perryg114's Avatar
perryg114
On my Excursion, I installed 6.0L cooler from the bottom. I don't think the F series has the blocker beam which makes it even easier. After removing the blocker beam below the main bumper I just removed the rubber guards held in with the plastic rivets and disconnected the hoses un did the 4 screws holding the old cooler in, removed the lower AC condenser mounts and carefully shoved the new one in. I did have to jack the front of the truck up to have enough room. I bought extra hose and 1/2" to 3/8" hose barb adapters from mcmaster.com. MAKE SURE YOU REPLACE the stock hose clamps on the new cooler.
Perry
Originally Posted by woodnthings
I have a 25 row cooler, and it does fine keeping temps down. I tow an 8500# trailer and have yet to see 180 degrees when towing. Got close once this summer when it was 100 degrees out, but I was only going 40 MPH. Empty I run 125-140 pretty much all the time.
I put together a "How To" for installing a 6.0 cooler based on the way I did mine. Everyone on all the forums seems to ask the same question so I put this together.
6.0 Cooler Install Write-Up
Ken
Old Oct 5, 2010 | 01:21 PM
cdrmotorsports's Avatar
cdrmotorsports
I ended up call Ford this morning. $475 for the 26 row and $560 for the 31 row Just got done ordering a 26 row from Ed for $375 shipped second day. Just regular ground it would have been $340ish, so not bad at all.
Old Oct 5, 2010 | 01:25 PM
cdrmotorsports
Awesome write up Ken. Reps to you.
Old Oct 5, 2010 | 01:36 PM
woodnthings's Avatar
woodnthings
Thanks! Hopefully it will save you some time and frustration!
Old Oct 5, 2010 | 01:56 PM
Brother Les's Avatar
Brother Les
cps
When I was Lead Hill getting a new BTS transmission, Brian was going to put a 6.0 on my truck. I said to just put in 'inline' with the 7.3 cooler that was on there. He told me that leaving the 7.3 cooler on the truck would Restrict the flow of fluid through the lines because of the size of the lines. Thus defeating the purpose of the new cooler to move more fluid.
Old Oct 5, 2010 | 02:13 PM
perryg114's Avatar
perryg114
The 6.0L Cooler has 1/2 inch lines and my old cooler had 3/8" lines so it should flow well.
Perry
Old Oct 8, 2010 | 08:39 PM
gcfisher75's Avatar
gcfisher75
I run 27,000 gvw with my 7.3 pretty regularly... Any advice onwhat I should use as a tranny cooler???? Lol
Old Oct 8, 2010 | 09:02 PM
Waynenap's Avatar
Waynenap
Originally Posted by Riffraff Performance
Are there detailed instructions for mounting these on our trucks?
Old Oct 9, 2010 | 06:38 AM
perryg114's Avatar
perryg114
Click Kens rightup above in an earlier post. He uses the top method. I used the bottom method which I described in an earlier post as well.
Perry
Old Oct 15, 2010 | 08:18 PM
  #28
cdrmotorsports
Finally got around to getting my 6.0L cooler in today. It was slightly more of a pain than I had anticipated, but not bad by any stretch. Those write-ups came in very handy. Thanks again guys. I look forward to seeing to cool transmission temperature reading when I get my gauges installed.
Old Oct 16, 2010 | 01:34 PM
  #29
RKern's Avatar
RKern
This is a good thread as I have been searching site looking for info on the 6.0 cooler swap after seeing it appear in peoples signature.
Old Oct 16, 2010 | 06:31 PM
  #30
perryg114's Avatar
perryg114
Mine got up to 150 F towing about 5k. It was not real hot outside maybe 70's. According to Mark Kovalski there is such a thing a too cold. I think he recommended around 170F. Too cold and it does not get all the water condensation out. Mine has been running 130-140 F running empty which is a little on the cold side.
Perry
diggintrenches
Mar 4, 2014 10:20 AM
clintusaf
Feb 9, 2012 12:48 PM
spotteddog
Dec 19, 2009 08:03 PM
Pinky Demon
Oct 4, 2009 01:03 PM
