Sponsored by: Real Truck
Heater Frustrations
Old Oct 5, 2010 | 12:54 PM
GUNNERDOG's Avatar
GUNNERDOG
I read this a little differently...
pin 7 to ground should have about 12V when in run
pin 4 should have 12V when in run
If you jump pin 3 to 7 you should get something less than 12V when in run and that value should change when you change the temperature pot **** position.
EDIT: of course you have to test these pins without disconnecting the connector (C289)
Actually, if you disconnect C289 you can just test resistance between 3 and 7.... there should be continuity, but it should have some resistance that should change when you turn that heat temp control ****... If you don't get any continuity between 3 and 7 then your **** is probably bad.
Old Oct 5, 2010 | 10:30 PM
cobra99999's Avatar
cobra99999
I was probing the terminals on the C289 plug & then the heat started all at once for some reason. I thought that some wires or terminals might be loose but I tugged each one individually but nothing unusual was found. Tried out different settings & all works well. It works now & I am happy with it but it may not work again. At least I am better informed on how it works now. Question for Mr Chamberlain, where do you find your info at ? It is super to know this stuff. Thank you & to everyone else.
Old Oct 5, 2010 | 10:34 PM
dchamberlain's Avatar
dchamberlain
I have a subscription to the factory Ford service manual from alldata.
It is ALLDATAdiy.com :: Leading Source of Diagnostic and Repair Information. Subscriptions start at 15.99 per year, I think. I'm not sure it's the best resource. Sometimes it's really hard to find stuff. But it's helped me a lot so far.
Old Oct 6, 2010 | 07:17 AM
GUNNERDOG's Avatar
GUNNERDOG
I bought the service manual CD from ebay. If you go that route make sure you get the one that doesn't require turning your system clock back to 2000...
peakswashere
Jul 13, 2020 09:26 PM
Daddyo's garage
Dec 25, 2016 11:51 AM
ExBeast
Jul 13, 2016 04:24 PM
conoso
Jun 18, 2016 07:32 AM
Rusty_S
28
Nov 29, 2015 07:28 PM
