The truck is a 1999 F250 with a 5.4L Triton engine. Never has any heat. Both heater hoses @ firewall get hot. Undone heater hoses & water from a garden hose flows thru heater core well. Have vacuum to black hose behind heater controls. Controls seem to move ok. Checked related fuses under dash & under hood. Also swapped relays around. No wires seem to be off under dash. Any ideas would be helpful, thank you
I don't know which direction you ran the garden hose through the heater core, but sometimes a reverse flush can get more crud out than one in the direction of normal flow?
I would suspect the blend door. It is controlled by an electric motor that is controlled by the warm/cool ****. I can't give you an exact location, but I have posted a general diagram below.
Yes, I was thinking that the problem with the heat was leading up to the blend door. I should have heat @ the heater core. If I had a laser shooting thermometer I could aim it @ the HVAC box. But I will first see if I have any power @ any time down to my actuator. Will try after I send the little man off to bed. Anyone know which wires down there are for what ?
Also, I was thinking that it is possible to have an air pocket trapped in the heater core area. I heard that if I whipped the hoses off then back on while running it may cure it. Of course its a messy process. Any tricks with this ?
I don't believe this is your problem. If it were, it would have to be preventing coolant flow through the heater core to be causing a problem, and if there wasn't coolant flow through the heater core, they're wouldn't be coolant flow through the hoses and they wouldn't get hot.
why did you wait 11 years to address this problem.you should have flushed the system years ago.this is called preventive maintanence.flush it with a good good cooling system flush.followed by a distilled water flush.then distilled water and the proper 50/50 anti-freeze solution.
Good tip about the coolant concentration percentages & so I had just bought this F250 about a month ago. The electrical breakdown is useful as with the engine running I only have power @ the #7 pin & ground @ #8 pin as noted. No power at any other pins no matter on the position of the temp dial or the vent selector position switch. Also... No power ever is @ either @ the 2 plugs that go to the back of the temp selector switch. Yet I have checked all pertinent fuses & swapped relays. The truck itself is in pristine condition. Anyway, still no heat...
I am thinking that I need power to these other pins on the plug as shown. I only have wiring on my truck to pins 3,4, 6,7 &8. No terminals on others in plug. Might need electrical schematic to backtrace through wiring.
These are the diagrams. They aren't labeled but the one with the blend door actuator and temp control dial is 54-4. It references connection C (triangle with a C in it) in diagram 54-1, which is the other diagram.
It appears that pin 7 of the connector to the blend door actuator is powered by fuse 28 in the Central Junction Box. Pin 8 of the connector goes to ground. The fuse number may be different, fuses did change between model years. Mine is a 2004 and I don't think the same fuse panel went back as far as 1999. The fuse is labeled "EATC module/Front blower relay coil" in my owner's manual. But that may be different in yours as well.
Pins 3, 4 and 6 are wires back to the heater control, and it appears from the diagram that you won't see any power on those, just a change in resistance as you turn the heat control ****.
