just for future refrence
Old Nov 6, 2010 | 11:15 PM
jg96powerstroker's Avatar
jg96powerstroker
Originally Posted by rideracelivemx7
its just a really tight place to work with tahts all, getting the rtv to seal, i think i have a pin hole somewere again. its annoying to do!
ok not to sound dumb or lost but are we on the spot where ic pipes hook with 2in orange boots??? if you do change these to 3in like from a sd can you then use the spider from a sd like a 2000??? i had my turbo off, when i did my d66 swap and man it sucked!!!
Old Nov 6, 2010 | 11:21 PM
oldbird1965's Avatar
oldbird1965
Originally Posted by jg96powerstroker
ok not to sound dumb or loost but are we on the spot where ic pipes hook with 2in orange boats??? if you do change these to 3in like from a sd can you then use the spider from a sd like a 2000??? i had my turbo off, when i did my d66 swap and man it sucked!!!
It sure did suck and I have to do it again
Old Nov 6, 2010 | 11:27 PM
jg96powerstroker
dude i hear that!!! you need a midgit with little hands!!!! hey glen i have my trany out and am in doing a 5 speed swap pop a good time to do up pipes aswell right??? i wish i had a trick to tell you on that turbo, i realy=ly think you will like it when she is working
Old Nov 7, 2010 | 07:40 PM
oldbird1965
That's for sure on the little hands! It was pretty funny last time I finally got my socket on the back drivers side pedistal bolt, then I couldn't reach my socket wrench. I held onto the extension with my right hand and pulled my cell out of my pocket with my left hand and called my wife. She came out and got it for me, it was laying just out of my reach!
Yes, yes do the up pipe gaskets while the trans is out. Now that's a judgement call, its up to you. The thing about mine, they were not leaking but I thought that as long as I had the turbo out I might as well change them out. Looking back I wish I would have left them alone. Oh well
Old Nov 7, 2010 | 08:15 PM
jg96powerstroker
lol i hear that on them pedistal bolts, i found the two pedistal bolts and socket i lost back in may when i droped them sat, i took inside hump cover off to do my trany swap and there they was on top the trany just waiting for me! lol would you still go with beans on there gaskets?? or just go stock or is there and up graded gasket you suggest?? i no beans kinda left a bad tast in your mouth
Old Nov 7, 2010 | 10:26 PM
oldbird1965
Same thing here, later on I found lost tools! As far as the donuts gaskets go, here is a quote from Ryan Bean before I had a falling out with him:
"If you have a Car-Quest car part place close to you they sell a Chevy 350 donut gasket that works real well also. The Part# is F-17250, CarQuest is the only place I have found that sells them because they are Victor Rienz instead of Felpro's. the Felpro's are too hard and will not compress enough. If you do go this route they will fit pretty loose over the pipe, grease them up really well and tighten down the marmon clamps like crazy till it seats the gasket all the way around. I have had real good success doing those like that. "
He didn't telll me a sucess story about the brass donuts. The brass donuts have to be heat retorqued. Like you said, you have to have midgit heads or little girl hands to do that. All I could get out of Matt at Beans is that he used a snub wrench?? I guess that's a wrench cut off??
Walleye Hunter
13
Nov 15, 2020 10:21 AM
ExPACamper
28
May 12, 2017 11:31 AM
z31freakify
Jan 21, 2016 10:54 PM
JuanHuevos
May 13, 2015 08:26 PM
nossliw
43
Jul 15, 2012 12:13 PM
