well took the old girl down to are shop about 20 miles away last night and 5 miles from the shop the trany had had enough!! the worst part of all was had 2 be pulled in buy a dam dodge!!! but got up and at it to day got all the auto out of the way and interer and floreing is moved, did some masering and i seam 2 be abot 2in short as of now, may have 2 have a short shaft in the rear lengthend, my 5 speed is out of a 93, now i thought i saw where some one said i can use my auto transfer case is that true??? if not ill stay with the old one and upgrade later. dose any one on here have a 96 or so crew cab 4x4 short bed 5 speed the could give me some maserments on thanks
You can use your t case. You might have to modify or fabricate a new linkage bar that runs from the 4x4 shifter to the t case. It's different lengths from auto to 5 speed and I think the BW 1356 and 4407 have different length link bars. But it is easy to shift it from underneath in the mean time and if you have a welder then there's no problem.
If the driveshaft from the donor is too short too then I'd just lengthen whichever looks better. I don't know anyone on here with a crew cab short bed 4x4 so you may just have to finish up and measure.
WTF! Ive wanted a crew short bed forever!!!!! I had a crew long bed and sold her to buy my extended cab..the four doors with 8ft bed was alot for one person lol
lol bube i got 3 kids! lol so you wanna trade?? i wanna long bed 350 so bad but they are all dullys here! i have a 93, long bed 350,maybe i should do a ps amd 5speed swap on it. gotta get her off her ford edge kick!
iam still beating my head against the wall trying to decide if i want to convert or not i think if someone with the same color truck offered an even swap,i would go for it
I've got it George! You should do it all! Then you could have a 1992 F350 7.3L IDI -> PSD, Dually -> single wheel, E4OD -> 5 speed, 2 -> 4wd. You would be the f n man.
