69' starting problems
Old Oct 3, 2010 | 03:13 PM
69flatbed's Avatar
69flatbed
Question 69' starting problems
I am working on a 1969 F350 with a 360/4 speed. The engine will turn over but won't fire what could be the culprits? And also there is about 1 1/2 gallons of gas in the tank is this enough for the pickup? thanks
Old Oct 3, 2010 | 04:18 PM
69flatbed's Avatar
69flatbed
coil or distributor cap maybe? anyone?
Old Oct 3, 2010 | 10:47 PM
Nod's Avatar
Nod
No fire
69 flatbed,have you checked for fire at the plugs?If you have spark then make sure the timing is set correctly.Check to see if you have gas at the carb,turn the engine over for about 20 seconds then with the key off and air filter removed climb up and look down inside the carb while you manually open the carb linkage completely.You should see gas spraying into the carb bore and into the engine.If not you could have a bad fuel pump or a bad accelerator pump.I would start with the fuel pump and if that is working then check the carb functions.Let us know what you find.
"bowties in the rearview mirror"
Old Oct 5, 2010 | 07:52 PM
69flatbed's Avatar
69flatbed
well i have gotten the engine to run, but with no alternator. The problem was that every time i hooked up the battery the alt. and red cable to the alt. would start to burn. What is going on? And are there pictures of the back of a hooked up alternator for a 1969 w/360?
sanders1016
Nov 25, 2013 03:37 PM
69cobrajet
New Member Introductions
Dec 16, 2007 09:16 PM
brownawell1
Sep 28, 2007 07:43 PM
Mil1ion
Dec 25, 2002 05:25 PM
jbhf250
May 1, 2000 05:26 PM
