Surface rust on Hood
Old Oct 3, 2010 | 12:55 PM
PDX_F250_78's Avatar
PDX_F250_78
Question for the body guys.
I have surface rust on my hood and want to sand and primer it.
I've never worked with metal before. What grit do I start with and what brand of primer would you guys recommend?
I won't be getting it painted till next year, but since I live in Oregon and we have really wet winters, I wanted to take care of the surface rust.
Old Oct 3, 2010 | 12:57 PM
77mud's Avatar
77mud
I did my old 88 the whole truck i used 120 grit and used rust oleum Auto primmer and it worked good lasted until i sold it...
Old Oct 3, 2010 | 01:13 PM
jim collins's Avatar
jim collins
I do old 30 model cars,if its surface rust I use 120 with a orbital sander. Then I use 2 coats of good primer ,hand sanding between them with 220 . let it sit until I'm ready to paint,sand again with 320 and use a primer sealer before I paint. I'm not a painter but thats worked for me most of the time. Sometimes I go at it a little different depending on how bad the body was and how much repairs I'v done to it.
Old Oct 3, 2010 | 05:26 PM
MiddleNameMUD's Avatar
MiddleNameMUD
120 grit is a good paper for rust with an orbital but if u plan to leave it in primer for the winter which is not the best thing to do, you will probably have to resand and prime in the spring. Make sure you use a primer that has a sealer in it, primer will absorb moisture and the cancer will bleed back through.
Old Oct 3, 2010 | 05:34 PM
PDX_F250_78
What would be the better thing to do instead of leaving it in primer? I don't have the money right now to paint it.
Old Oct 4, 2010 | 06:32 PM
MiddleNameMUD
There is not much else you can do other than saving your money and doing it properly. If you want to do a winter "bandaid" and I mean Bandaid! sand it down, prime and do a temporary paint job on it with a couple spray bombs and when you go to paint it, sand it back down to primer and prep for paint. Whatever you do DO NOT use tremclad or any oil based rust paint, you will have to strip it all the way down to the metal and start over. good luck!
Old Oct 4, 2010 | 08:38 PM
OldFordCollector's Avatar
OldFordCollector
I have had a 66 mustand in black primer now for 5 or 6 years. I simply added a little flat black paint to the primer and it does just fine.
Old Oct 4, 2010 | 08:59 PM
1977f150xlt's Avatar
1977f150xlt
we used a air sander, and 100 Grit sandpaper, then we had to use a thin layer of body filler to get out a few pings, and then we sanded it all smooth, and then coated it with a nice coat of Black epoxy primer, did the entire truck and frame with that stuff as well during the frame off restoration, then we followed up with Grey filler primer on the hood and body, and then sanded that down smooth, then we did a few more coats of primer and sanding, and then finally tacked it all down and blew it off with the air compressor, then some coats of paint, and then of course clear coat, (of course there was more too it than just that, as the cab corners and bed had panel repairs done, so it took awhile!)
i would get it clean of rust, then get it sealed with primer and some paint, even just temporary paint from a spray can would be better than just leaving it rusty, or just leaving it in primer, as primer tends to absorb moisture, so unless you can store it in a garage for the winter, and your not driving it, then it would be fine, but i would get it sealed before winter,
-Brent
78 & 87 Super Cab
Jul 16, 2014 10:51 PM
Ripcity
Sep 2, 2013 08:48 AM
jvmcc
Paint & Bodywork
Aug 29, 2013 08:31 PM
effie1
Paint & Bodywork
Oct 29, 2009 06:09 PM
Ford79
Paint & Bodywork
Jul 3, 2009 01:35 PM
