NEED HELP FOR PROBLEM
Old Oct 2, 2010 | 06:53 PM
harley51's Avatar
harley51
Question NEED HELP FOR PROBLEM
I need to know how to repair, the overdrive on a 4 wheel drive,(explorer,xlt) The overdrive light comes on at times. If I restart the engine it is good for awhile. Has anyone else had this problem?
THANK YOU for any help.
Old Oct 2, 2010 | 08:39 PM
shorod's Avatar
shorod
Welcome to the forum!
Is it the "OD Off" indicator that comes on? If so, you might have a broken wire in the shift lever/column for the OD Off button. It's a fairly common issue.
What year is your Explorer and which engine does it have?
-Rod
Old Oct 3, 2010 | 07:18 AM
ncranchero's Avatar
ncranchero
Ford Explorer Ranger Enthusiasts "Serious Explorations"® - Search Results
That search topic will give you loads of reading material, not much of it good news for you unfortunately. Your problem "may" be as simple as one of the solenoids in the transmission but it may be worse.
Old Oct 4, 2010 | 04:23 PM
harley51's Avatar
harley51
-Rod
The OD light flashes,engine is a 4.0, year is a 99XLT, I had the OD button replaced
thanks for the info and any additonal information that you can give.
Robert
Old Oct 4, 2010 | 04:53 PM
ncranchero's Avatar
ncranchero
The OD light flashing indicates a transmission "problem". Getting the codes read will tell you what problem. The OD button is just wishful thinking.
harley51's Avatar
harley51
How would I know which solenoid it is ? Also, can I get to it without pulling the transmission? Thanks for any and all help.
Robert
KingProvince
Mar 22, 2017 11:53 AM
siringo1880
2004 - 2008 F150
Sep 22, 2015 10:24 PM
blackwidowrealtree
13
Feb 6, 2015 07:17 PM
smithcl7
Feb 29, 2012 07:00 AM
vaughn_roberts
Oct 13, 2004 08:21 PM
