400 FMX Value
Old Feb 22, 2003 | 11:49 AM
CJJTulsa's Avatar
CJJTulsa
400 FMX Value
Located a 400 with the small bellhousing pattern today. Guy wants $135 for the shortblock -- he pulls it out, I break it down to the short block. Is this a good deal?
Old Feb 22, 2003 | 12:24 PM
CJJTulsa's Avatar
CJJTulsa
400 FMX Value
This Ranchero that it's in has a "U" code for the trans., which translates to a C6. But it definately has a bolt-on bellhousing, and there is a ridge around the back of the block where a big-block style tranny usually bolts up, with no threaded holes. The bellhousing is about 2-3" lower than where all the rest of the 400s I've seen bolt up -- at least that much lower than the rear deck of the block. I couldn't see if it had the raw castings for the small block motor mounts, manifolds and other stuff was in the way.
Old Feb 22, 2003 | 11:00 PM
GT40man's Avatar
GT40man
400 FMX Value
yes, good deal. do check to see if it has the 7 cyl mod.
lol
Old Feb 23, 2003 | 05:56 AM
CJJTulsa's Avatar
CJJTulsa
400 FMX Value
Would that be a rod through the block? This one (so far) appears to be intact, I hope there isn't a problem with the bottom end.
Old Feb 23, 2003 | 10:16 PM
GT40man's Avatar
GT40man
400 FMX Value
thats were you have 6 "normal" cylinders, and one extra large one.
i bought 2 site unseen blocks that were both that way. it was 3 blocks that supposedly ran, paid $50 for the bunch.
Old Feb 24, 2003 | 01:06 PM
CJJTulsa's Avatar
CJJTulsa
400 FMX Value
Was the "blowout" towards the bottom of the cylinder, or to the top (or both)? I take it you would know if you spun the crank, or couldn't as the case may be. I'm sure removing the heads would make this obvious.
Old Feb 24, 2003 | 02:02 PM
Billy Freeman's Avatar
Billy Freeman
400 FMX Value
Was this small bellhousing a factory mod? I was unaware that this was ever done. How rare are these?
Old Feb 24, 2003 | 02:32 PM
Bill_Beyer's Avatar
Bill_Beyer
400 FMX Value
It was done for 1 model year, 1973...why? I have no idea. How many were cast? No clue. I've never seen one in person not that that means much but it seems like they are a fairly rare bird.
Old Feb 24, 2003 | 02:49 PM
CJJTulsa's Avatar
CJJTulsa
400 FMX Value
I'm a little concerned about the one I found in that it was cast at the Michigan Casting Center, which produced blocks that were prone to cracking in the water jacket area in the lifter valley. I jerked the intake, and didn't see anything unusual, but I'm still a bit concerned. Should I go ahead and get it?
Old Feb 24, 2003 | 04:53 PM
Bill_Beyer's Avatar
Bill_Beyer
400 FMX Value
I don't blame you for being concerned. I used to think that if an engine made it for over 20 years without cracking that there was a good chance it would last for another 20 without cracking but I know 2 guys who in the past 2 years have completed rebuilds on MCC blocks, 1 with a pre 3/1/77 casting date and 1 with a supposedly good date who have had the blocks crack in the lifter valley after the rebuild.
Old Feb 24, 2003 | 10:06 PM
GT40man's Avatar
GT40man
400 FMX Value
in my case it was the cyl walls on the left bank. i found out later the owner had abused the engines. i dont think it was a factory defect, just over reving on a lean issue.
Old Feb 26, 2003 | 06:12 AM
73XAFalcon's Avatar
73XAFalcon
400 FMX Value
Saw your post of the 351C board. $135 is a good price to someone. It could be a good price to you if you have a use for this block. First, do you have a 351C or SBF application that you would like to replace with a 400? If you have a Clevo, then this is a cheap alternative to a stroker 351C. If you have a 351W, well the parts are so plentiful now that building a killer W is often a better (and cheaper) option. I saw cheaper because you don't have to buy all the little stuff like brackets and front engine dress, etc.,.... Biggest thing is to check out the block and see if it is cracked of beyond boring. If you still don't know if you want to tackle this job, e-mail me.
jmobley2002(No Email Addresses In Posts!)
--J
Old Feb 27, 2003 | 05:57 AM
CJJTulsa's Avatar
CJJTulsa
400 FMX Value
Tried to reply yesterday, but my e-mail was messing up. Don't know if you got it or not. If not, I can try again today.
sugar
Dec 19, 2003 01:10 PM
trinogt
24
Aug 20, 2002 07:08 PM
teamwizard
Mar 31, 2002 12:15 AM
85351ho
Feb 24, 2001 11:05 AM
Bruce
May 1, 2000 09:11 PM
