The cam I put in has a gross lift of 524. Went with roller rockers, stud conversion kit and heat treated pushrods. Hopefully this should perform quite well. Anyone done this?????
Got valves springs to match on order, also getting high volume oil pump and 9 quart pan. This is the first step, next will be Weiand 8010 intake and 4brl as well as headers. This combo should perform!
