folks hi, new batery, alternador,regulator.......it chager ok, but on my ohm meter sad 18.05 or 19.70 volts and the normal is 14.05 to 15.50 volts !!!..... ford van serie econoline 4.9 300cc 6L 1984
i can find the problem !!!
help and thanks friends
Reason: ok
Make sure regulator has good ground where it is screwed on.
Check the "A" wire. See if same voltage on "A" wire at regulator same as at the battery post.
If voltage same and good ground at regulator then change regulator.
