door locks again 2001 Ford Excursion
Old Oct 1, 2010 | 09:51 PM
cstock's Avatar
cstock
Ok only my back power door lock works( both keyless and button/ locks and unlocks). Front and rear poassenger doors won't lock or unlock with keyless or button but all will lock/unlock manually. Checked actuators, did the foil fix and all locks worked perfectly for about 4 yrs. Whats weird about this time is they all quit at once (except like I said the back works). I can hear the relays in the security module behind the radio clicking when I use both the keyless and the buttons but it's like the current is too low to go ahead and hit the threshold to activivate the actuators. Could all the actuator motors just be warn out? Is there something bleeding off the voltage? I metered the actuator leads while pressing lock and unlock and did get a spike but it's so momentary I can't see what voltage my meter is peaking at. I hooked it up to an external 12 volt supply and it worked fine? thanks Charlie
fmjnax08
1997 - 2003 F150
Jan 28, 2011 02:06 AM
cstock
Electrical Systems/Wiring
Oct 13, 2010 09:21 PM
HuskerMedic
Mar 5, 2009 04:42 PM
gungho351
Jan 25, 2006 09:24 AM
cowboylukas
Aftermarket Products
Jan 2, 2006 03:56 PM
