2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
no heat or air thur defroster
Old 02-01-2018, 02:51 PM
03psd73's Avatar
03psd73
03psd73 is offline
Like the title says I dont get any heat thur the defroster or floor vents. Read some that says it mifgt be a "mod door" . one site I read says it is elec. I thought most fords used vacuum operation? Is it on the pss side under dash like the rest of the system? What other things can I check to see what the issues is. Thanks
2007 expy 4x4 el
Old 02-02-2018, 10:57 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
As far as I know in 2007 it's still vacuum controlled. There is one vacuum actuator that controls the defrost and heat airflow so I would suspect that actuator as being the problem.
Old 02-02-2018, 12:23 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The mode door actuator on an 07 Expedition is electrical. '06 appears to be the last year for vacuum-operated HVAC actuators on the Expy.
The actuator is on the driver's side, up above and inboard from the accelerator.
Old 02-02-2018, 01:45 PM
03psd73's Avatar
03psd73
03psd73 is offline
Thanks sho gonna go take a look now
smsperformance
1997-2006 Expedition & Navigator
04-04-2015 10:30 PM
John McCord
11-18-2013 10:23 AM
drivembig
01-09-2010 04:25 AM
ladelld33
06-15-2009 08:56 PM
zmurphy
05-14-2008 10:32 PM
Quick Reply: no heat or air thur defroster
