Ford Truck Enthusiasts Forums
-   2007 - 2014 Expedition & Navigator (https://www.ford-trucks.com/forums/forum174/)
-   -   no heat or air thur defroster (https://www.ford-trucks.com/forums/1526557-no-heat-or-air-thur-defroster.html)
03psd73 02-01-2018 02:51 PM
Like the title says I dont get any heat thur the defroster or floor vents. Read some that says it mifgt be a "mod door" . one site I read says it is elec. I thought most fords used vacuum operation? Is it on the pss side under dash like the rest of the system? What other things can I check to see what the issues is. Thanks
2007 expy 4x4 el
alloro 02-02-2018 10:57 AM
As far as I know in 2007 it's still vacuum controlled. There is one vacuum actuator that controls the defrost and heat airflow so I would suspect that actuator as being the problem.
projectSHO89 02-02-2018 12:23 PM
The mode door actuator on an 07 Expedition is electrical. '06 appears to be the last year for vacuum-operated HVAC actuators on the Expy.
The actuator is on the driver's side, up above and inboard from the accelerator.
03psd73 02-02-2018 01:45 PM
Thanks sho gonna go take a look now
