Minnesota Chapter Join Chapter, Leader: fordpower88
Oct BS Thread Lets have 3,333 posts
Old Oct 15, 2010 | 07:01 PM
  #811
fordpower88's Avatar
fordpower88
Originally Posted by dlibson
Evening guys!
That looks like quite the accident Troy.
Hey Dave!! Yeah it was quite the sight for sure!!
Old Oct 15, 2010 | 07:57 PM
  #812
arnoldhunter's Avatar
arnoldhunter
Good evening guys.
I'm glad everyone was okay and that it was only a Deere that got mangled.
Old Oct 15, 2010 | 08:01 PM
  #813
fordpower88
Hey Eric!!
Yeah it was good no one got hurt bad! You might be able to pick the tractor up cheap. Should I get you some info? LOL
Old Oct 15, 2010 | 08:11 PM
  #814
dlibson's Avatar
dlibson
Hey Eric, Troy!
Gonna fix up the roof on the camper tomorrow...
Old Oct 15, 2010 | 08:17 PM
  #815
fordpower88
Hey Dave! How you planning on fixing it up?
Old Oct 15, 2010 | 08:21 PM
  #816
dlibson's Avatar
dlibson
Well I am going to reinforce the wood underneath then glue the rubber to it. Then I have to cut the front bar in half and stretch the rubber back under it and re-screw it down. After that some fresh caulk and done. At least that's the plan in my head! LOL
Old Oct 15, 2010 | 08:26 PM
  #817
fordpower88
Well it sounds good! Make sure and post back how it actually went! lol
Old Oct 15, 2010 | 08:29 PM
  #818
dlibson's Avatar
dlibson
Will do Troy, I hope it works as planned.
Old Oct 15, 2010 | 08:32 PM
  #819
fordpower88
Me too!! It sounds simple enough! Say have you got any numbers put together for my tow truck?
Old Oct 15, 2010 | 08:38 PM
  #820
dlibson's Avatar
dlibson
I was working on it today some. I'm somewhat confused on what front end you have. According to my system that's the front-end that has bearing systems for joints. Not an actual joint. It was hard to see in there the other day though. If that is right, it doesn't have any adjustment period. So I'm wondering what that guy actually did. Back in the day when those were common, we used to swap newer front ends in them...
Old Oct 15, 2010 | 08:50 PM
  #821
fordpower88
Weird....is there something I can look at to help figure out what is in there?
Old Oct 15, 2010 | 08:58 PM
  #822
dlibson's Avatar
dlibson
Yeah it is crazy...
What you can do is pull the cover off the top joint and see what is there. Jack up one side, pull the tire off, and then the cap. See if it is a bearing under there...
I am trying to pull up some info, but I can't log-in right now for some reason...
Old Oct 15, 2010 | 09:01 PM
  #823
fordpower88
I can do that no problem but will probably be sunday or monday before I can get to it.
Old Oct 15, 2010 | 09:04 PM
  #824
dlibson's Avatar
dlibson
It still can have ball joints too Troy. It looks like 90 was the cut off point...
As for tires. $150 gets you a pretty good tire. There are options in either direction of price that are still okay...
Old Oct 15, 2010 | 09:06 PM
  #825
dlibson's Avatar
dlibson
That's fine. I'm still looking for a diagram to...
It's sad how hard it is to find stuff from the early 90's already...
