79 f150 steering columns
Old Sep 30, 2010 | 02:45 PM
f350on38s's Avatar
f350on38s
Alright i just baught a new project its about 5 different colors and needs some work but that why i baught it. i have a few steering columns laying around from previous projects seeing how this is number four, they have all been a 79 and 1 78. So to get to the point i have 2 4wd steering columns and one 2wd, the 2wd column is the nicest but i need the 4wd steering shaft the splined end not the rag joint end. i was woundering if the only difference between a 4wd and a 2wd column is the shaft ends. i was thinking that maybe i could pull all the internals out of the 2wd column and which the shafts and go with that. the two 4wd ones as a little rough i have one were its got some rust from being in a mud truck but nothing a little tlc wouldnt take care of and the other 4wd one is broke somewhere internaly. so sould i take the easy route and clean up the rusty one or should i go the not so easy route and switch all the internals out? thanks for the help and ideas and sorry for any confussion there might be.
dan
wlittle
Jan 14, 2012 12:56 AM
Big Daddy T
Apr 15, 2010 10:39 AM
benmoderow
17
Dec 17, 2009 09:56 AM
highboy 74
Nov 24, 2004 06:35 PM
SeaDooPhil_78
May 18, 2003 02:06 PM
