Sponsored by: Auxito
check engine light but no problem
Old Sep 30, 2010 | 10:04 AM
djones21's Avatar
djones21
ever here of the light coming on, but no problem, just had my truck with 171,174 codes, took it to a mechanic, changed the intake gasket , which is what i thought it was, ( already did pcv, vacuum hoses, cleaned maf, fuel filter) now the light is back on, mechanic says sometimes the light trips back on , but no problem, he inspected it, so im guessing the computer showed , at least yesterday that it is fixed,,,,anyone hear of light coming back on like that? going to get codes read again later today??
Old Sep 30, 2010 | 10:35 AM
minitrk's Avatar
minitrk
If there is no problem there would be no code. Did you do the vac elbow on the back of the intake?
Old Sep 30, 2010 | 03:59 PM
projectSHO89's Avatar
projectSHO89
...if there wasn't a problem, the light wouldn't be back on....
Old Oct 1, 2010 | 12:25 AM
KhanTyranitar's Avatar
KhanTyranitar
Those codes are serious codes. My brother had the same code on his van, ignored it, and the heat from the lean condition warped 2 valves. Check your fuel pressure, a weak pump may be the next suspect on your list.
Old Oct 1, 2010 | 12:36 AM
pooch4428's Avatar
pooch4428
1997 F250 7.3 powerstroke Deisel
my son ran my truck out of gas. I put fuel in it got in fired it up and started down the road. it is missing and don't have no power. I changed the fuel filter thinking it may have picked up access dirt out of the tank but no luck any ideas what may be the prob??
Old Oct 1, 2010 | 01:24 PM
minitrk's Avatar
minitrk
dirty sock on the fuel pickup in the tank
mebe2k
6.7L Power Stroke Diesel
Feb 27, 2021 08:18 PM
m4ryj4y
Sep 10, 2015 01:44 PM
ilikefords
Sep 9, 2015 11:37 AM
jetdoc
13
Jan 29, 2014 06:44 AM
stan ray rolls
1983 - 2012 Ranger & B-Series
Jun 5, 2002 03:48 PM
