351/400m overhating problems
Old Sep 29, 2010 | 07:26 PM
jonlucille's Avatar
jonlucille
I have a 351/400m that I had re built about 18 yrs. ago. I start and run the engine about every six months. Now I am attempting to drive the vehicle every day but it overheats after about 5 min. i have checked the waterpump ,tstat, installed new rad. and electric fan with shroud. Everything checks out ,but it still over heats????????????? Also I don't know what year the engine is ,how can i tell?
Old Sep 29, 2010 | 07:33 PM
ctubutis's Avatar
ctubutis
Are you relying on the factory gauge to tell you it's overheating? Five minutes seems pretty
short but I guess your thermostat could be stuck closed.
In any case, I'd verify the temp....
Old Sep 29, 2010 | 10:27 PM
jonlucille's Avatar
jonlucille
No need to verify temp, water gushes out of radiator after 5 min. ,with or without the tstat
Old Oct 4, 2010 | 01:03 AM
tbear853's Avatar
tbear853
What kind of thermostat? 351M / 400s (and maybe the 351C I think) have the bypass cast into the block, it's the hole below the thermostat. With the correct designed thermostat, as the water heats the thermostat opens and while opening, the lower portion starts blocking or restricting the opening into that bypass thus forcing the water to take the path of least resistance .... that being the radiator.
With the wrong thermostat or with no thermostat, there is no restricting action and water flows unrestricted through the bypass right back into the water pump and back through the motor without ever going through a radiator. Only a small portion actually goes through a radiator then.
The ones I use are Robert Shaw Flow Cooler 333-180, though you can get a 160 or 195. If you use the one's intended for a 351W or 289 / 302, etc ... it will overheat.
If I knew I had the correct thermostat with the restrictor plate that starts restricting that opening, then I'ld run a compression test.
I'm thinking head gasket or cracked head maybe.
Links on T-stats for the 351M/400.
https://www.ford-trucks.com/forums/8...ermostats.html
https://www.ford-trucks.com/forums/7...ml#post5793118
Old Oct 4, 2010 | 11:49 PM
grclark351's Avatar
grclark351
could be pieces of loose scale blocking the front passage at the head gasket, acts the same as if the head gasket is on backwards
Old Oct 5, 2010 | 08:02 AM
80broncoman's Avatar
80broncoman
18 years?? how old is the coolant mixture?? if it is over 3 years I'd flush it with water NO matter how miles are on it. It does turn acidic over time (in a engine, not in the plastic bottle.)
Old Oct 6, 2010 | 09:01 AM
mark a.'s Avatar
mark a.
Have you done a psi test on the system & cap yet ?
Old Oct 6, 2010 | 02:57 PM
joshlang's Avatar
joshlang
[quote=tbear853;9399473]What kind of thermostat? 351M / 400s (and maybe the 351C I think) have the bypass cast into the block, it's the hole below the thermostat. With the correct designed thermostat, as the water heats the thermostat opens and while opening, the lower portion starts blocking or restricting the opening into that bypass thus forcing the water to take the path of least resistance .... that being the radiator.
thanks for this post, i was having the same problem out of my 351m, after reading this i checked and sure enough i had the wrong t-stat.. you just saved me quite a bit of time and money
Old Nov 12, 2010 | 09:49 PM
tbear853's Avatar
tbear853
You're welcome sir!
77'FORD_man
19
Apr 18, 2012 11:51 PM
blownz
Feb 25, 2008 12:48 PM
CharlieLed
22
Aug 30, 2007 05:18 PM
roostenmotherbrother
13
Jun 1, 2007 09:18 PM
fe4ever
Jan 22, 2001 12:49 PM
