doh!
Old Sep 29, 2010 | 07:08 PM
Danger_Dave's Avatar
Danger_Dave
doh!
i just converted from bendix power steering to ford saginaw power steering. i put everything fresh and new. after bleeding it with fresh fluid and feeling how great it now is, i was so excited i went ahead and drove it to work........and hit some traffic. felt a humming/grinding. i waited till i got home to check it. the thing was so hot i couldnt touch the dipstick and there was fluid everywhere. it overheated, pissed out all the fluid, then ran dry and overheated some more.
i was not running any type of cooler. this is one of the stupidest things i have ever done. am i looking at a catastrophic failure? or maybe just a diminished lifespan? i bought a cooler now and plan on running it the way it is, and definitely dont feel like swapping the box back out again. it was a nightmare to do by myself. if i am only looking at buying a new pump that would be okay but i am pretty sure the whole system had a meltdown.
Old Sep 29, 2010 | 07:17 PM
4x4jedi's Avatar
4x4jedi
Give it a drink and see how it feels. You might just need a new pump. The box probably didn't even know it was hot
Old Sep 30, 2010 | 04:01 PM
Danger_Dave
what? lol. the thing is i have this new cooler here i spent 75 dollars on. its nice. and i dont want to risk getting it clogged up or gunked up if the seals and gaskets have fried and may carry that through the system, and/or metal shavings possibly from metal parts rubbing together with no fluid.
my real question is wheter the box is toast, or if in this type of situation the pump is really the only part that suffers, and anybody who knows anything about power steering or has had a similar situation.
Old Oct 9, 2010 | 05:13 PM
Danger_Dave
can anybody help me? i am thinking of swapping the box back out tomorrow and really dont want to have to do it.
Old Oct 9, 2010 | 08:35 PM
Ford_Six's Avatar
Ford_Six
You won't plug the cooler beyond cleaning if there is stuff in the box or lines. I'd just replace the pump and put some sort of filter on the return side in case there is debris. Biggest issue is that the box may leak.
Old Oct 10, 2010 | 08:25 PM
71 Sport Custom's Avatar
71 Sport Custom
Dave there a filters made to go in transmission lines. Maybe one of them would work in your return/low pressure side. I would keep a close eye on it as if it got clogged you'd be right back where you started. If it doesn't have anything in it it'll make you feel better about your "situation" Good Luck
Old Oct 11, 2010 | 12:43 AM
cj06's Avatar
cj06
fill it up and try it again , if there is damage it is already done ! not every vehicle came with a power steering cooler , and if there was a problem to start with it will still be there and a cooler wont fix it ! WAS THE PUMP MATCHED TO THE BOX ?
Old Oct 11, 2010 | 01:09 AM
xstrange's Avatar
xstrange
You may have fried the pump, but you probably didn't hurt the box. Unless you sent a bunch of ground metal particles into it.
The bigger question is what happened that made it overheat? Driving in traffic shouldn't cause that. You're only working the power steering system hard when you're doing a lot of lock-to-lock parking lot maneuvering. Otherwise it should be cruising and not building up any heat in the fluid. So, something must be wrong with your original installation.
Old Oct 11, 2010 | 03:18 PM
Danger_Dave
thanks for the help guys. i went ahead and got a new one since it was under warranty and autozone was very helpful. the pump was about a year old, and since the bendix leaked horribly i have run that pump dry a few times. a new pump will be on the way. as far as i know the pump is the same either way, so are the lines, i only say this because i havent found one that is "saginaw specific"
