4x4 swap - one issue
Old Sep 29, 2010 | 05:53 PM
bshep's Avatar
bshep
Hey not sure if anyone here did a 4x4 swap but I finished mine up last Feb. and its been working for a while. I haven't really went too far with it just a few miles down to the lake and what not. I took it for its first big trip today and hit a bump on the highway on the pass side and the pass wheel bounced up and down and it felt side to side. Steering wheel was shaking all over the place then it settled down. I was wondering if a loose track bar could cause this? anyone ever have a track bar loose or disconnected? Im not sure if mine is loose as its wet here and i didnt want to jack it up in the rain.
Any help would be great.
On a sad note - I;m selling the truck to my dad lol
Old Sep 29, 2010 | 09:02 PM
tecgod13's Avatar
tecgod13
interesting... Thats the same thing I think mine does on occasion. Only seems to happen when going above about 40mph, and hitting a large bump (or hole?) on passenger side. Abruptly stops when slowed down to like 25ish.
Details on my truck. 88' F250, was 2wd, now 4wd with Dana 60 SAS. Custom pieced together front suspension with gasser F250 leaf springs with reversed shackles. I never installed the trac bar. Last fall I shimmed the kingpin shims, and I thought had licked the problem. Except for a few random wobbles with big bumps, it didn't happen until about 3 weeks ago when the problem returned.
Ideas???
Old Sep 30, 2010 | 04:52 AM
cj06's Avatar
cj06
i swapped out a dana 44 out of a 77 f-250 and put it under my 89 f-250 4x4 ttb
and rancho 4 inch lift springs and it bounces like a pogo stick , and i even made sure that the caster was correct . i think that the leaf springs are the problem , with them having
one side that is extra long , i am at the conclusion that to make it work better you should turn the springs around ( long end forward ) and reverse the shackles . it would require
some fabrication to do it !!
Old Sep 30, 2010 | 12:33 PM
oreocreaming's Avatar
oreocreaming
as far as the d60, is it a kingpin axle? if so, they need to be rebuilt. you can help by adding a steering dampner but you can help by doing a kingpin spring eliminator kit. its a bolt that you preload against the kingpin. you just have to keep them adjusted. as far as the OP goes, yes, a loose trackbar will do that, also you need to check your knuckle back degree angle. if its straight or leaning forward then its gonna do that. if you put a degree shim to lean it back then you will track straight and eliminate that issue. if your running up to a 35" tire then you should always have 1 steering dampner, if you have larger then 35 then you need 2 shock setup. also, check your balljoints. you'll get that death wobble if they are worn as well.
Old Sep 30, 2010 | 12:37 PM
oreocreaming
didnt notice you said the caster was already set, put it back another degree.... as far as switching the leaf NO, it will push it so far back you'll never get to turn without removing or cutting your fenders big time. also, the shackle reverse kit is something i just did..... you cant get away with less then 3" of lift. you can get the kit at sky-manufacturing.com they are the cheapest place you'll ever find. it makes a softer ride, but thats not going to cure your problem.
Old Sep 30, 2010 | 01:10 PM
cj06's Avatar
cj06
you can not simply turn the leaf spring around with out fabricating new mounts ! that includes moving the front around 6 inch or so forward and building a new shackle in the rear .
Old Sep 30, 2010 | 01:22 PM
wreckinball's Avatar
wreckinball
x 10 for the steering stabilizer. You have to have those, and stick with the sizing like oreo said. When i flipped the springs on my 49 ****** pickup and got an effective 12 inch lift, i had the same problem. Had to run duals but when i did, it went away. every time you hit a bump it will do that.
Old Sep 30, 2010 | 03:39 PM
tecgod13's Avatar
tecgod13
Yes its a kingpin axle. What do you mean by rebuilt? I've looked at both sides and its didn't look that bad. Some pitting on the kingpin, but nothing looked worn except the seals. I got a rebuild kit and did everything on the passenger side except the kingpin it self (didn't feel like fighting it, and how the hell would it wear out before the plastic bushing??) . That did nothing for the problem, so I shimmed the hell out of both sides with washers. Its preloaded to the point that the spring is completely compressed, I'm fairly certain thats not a great thing.
Since I'm DON"T HAVE a trac bar, would putting it on help? I'm baffled because it didn't happen for about a year, then magically came back. The only thing I can think of is that I swapped the tires around, but that shouldn't matter... I've read that with the reverse shackle kit, trac bar is optional, so I never installed it.
Old Sep 30, 2010 | 05:52 PM
bshep's Avatar
bshep
Mine is a D60 as well and its only above 40mph big bump. The track bar actually was disconnected on one side. Not sure why maybe i forgot to bolt up when i did the swap. I cannot get the bar to bolt up. Do you guys think this is the issue or is it a sterring stabilizer thing? So any guys here have no track bar out front and a stabilizer and have noe issues?
Old Sep 30, 2010 | 05:56 PM
cj06's Avatar
cj06
none of the old fords or dodges or chevys had a trac bar , that was with leaf springs
i never new why ford put one on these newer one ? my only guess would be the front shackle is small as not being wide and ca easily bend side ways !! just my guess !!
Old Sep 30, 2010 | 06:45 PM
oreocreaming
the track bar helps keep your steering from going crazy. My company's F450 track bar bracket broke and it was terrible death wobbled and shaking like crazy. To hook it back up is easy. Just jack up the passenger side, that will move the axle closer to the bar. You have a balljoint or kingpin D60?
Old Sep 30, 2010 | 07:06 PM
bshep's Avatar
bshep
Mine is a King Pin D60. i'll seeif i can bolt it up. If not i might look at making one with heim joints I think that might be the cheapest way to go.
Old Sep 30, 2010 | 07:19 PM
oreocreaming
ya, you can buy one from sky-manufacturing for 125 or build one for 100.
Old Sep 30, 2010 | 08:52 PM
Coalroller's Avatar
Coalroller
oreo i was gonna ask you if your shackle reversal you made smoothed up ur ride any?
Old Sep 30, 2010 | 08:53 PM
Coalroller's Avatar
Coalroller
and i had 35s on my truck before and i then put a steering stabilizer on, noticed a difference (good) and now i have 37s and am in the process of making the dual steering stabilizer for it
