Paint decode
Old Oct 4, 2010 | 06:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by steponit
IIRC, his is a77
His is a '77 but he wanted the dimensions for the type 2 stripe. That was used only on the '75 Explorer.
Old Oct 5, 2010 | 07:27 PM
F-O-R-D #1's Avatar
F-O-R-D #1
Thanks so much Mike,actually i will lay them out by tape and spray them that will not be a issue,truck is a flat bed dually and should have told you that.I understanp your deminsions other than the 3 1/2 on the side of cowl...also colors have changed..now it will be dark jade with another ford green stripe.Thanks and it is a one month deal so i will post pics when finished...hope to return the favor!!
Old Oct 5, 2010 | 08:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Oops, I left out one dimension that would allow the 3 1/2" to make sense. I'll try and explain.
The 3 1/2" is measured from the back edge of the hood. The second dimension, 4 1/4" is measured from the bottom edge of the hood, directly below the 3 1/2" measurement. The 4 1/4" is the top of the tape stripe and the 3 1/2" forward is where the tape curves up and over the hood.
Hope this explains it.
Old Oct 5, 2010 | 08:24 PM
steponit's Avatar
steponit
You know,you could make a ton of money by reproducing all years explorer striping and free-wheeling striping in vinyl.
Old Oct 5, 2010 | 10:01 PM
F-O-R-D #1's Avatar
F-O-R-D #1
I get it thanks...yeah you could would have to have licencing?Or just change it 2%?Hell i just paint them on
moedaddy
2009 - 2014 F150
Mar 5, 2017 08:37 AM
bucksson
Feb 3, 2017 04:28 PM
speedyweasel
1978 - 1996 Big Bronco
40
Jun 12, 2012 05:13 AM
enduringexplorer
Appearance & Dress-Up
Aug 4, 2007 07:50 PM
fblake
Jan 19, 2002 11:45 PM
