Brake jod questions
Old Sep 28, 2010 | 10:33 PM
Dutter's Avatar
Dutter
Brake jod questions
Im getting new front brake pads, and when i take in my discs to be turned do the inner bearing have to come out, and how do i get the cylinder on the caliper to compress in, to fit over the new pads
Old Sep 28, 2010 | 11:00 PM
Nealcrenshaw's Avatar
Nealcrenshaw
you can remove the bearings, you compress the piston by using a big enough c clamp preferably while the caliper is still bolted in.
Old Sep 28, 2010 | 11:30 PM
Dutter's Avatar
Dutter
Alright, i tired a wood clamp, Ill try a C clamp then
Old Sep 28, 2010 | 11:37 PM
88 250's Avatar
88 250
Use a big c clamp with an old brake pad to push the piston back in. The caliper doesn't have to be on to do this I find it easier to do it while it's off. You can take the bearings out, who ever is going to spin them will most likely take them out anyways.
Old Sep 28, 2010 | 11:39 PM
88 250's Avatar
88 250
Also make sure to take you're brake fluid cap off before you compress the piston in.
Dutter's Avatar
Dutter
alright, ill try that too, and take out the bearings
Old Sep 29, 2010 | 08:35 AM
jas88's Avatar
jas88
The bearings must be out to turn the rotors.
Old Sep 29, 2010 | 10:08 AM
Dutter's Avatar
Dutter
Talking
Ok Thanks ill do that
ren60
1997 - 2003 F150
Jun 19, 2014 05:27 PM
Bruker
General Automotive Discussion
Jul 16, 2010 08:23 PM
scrooge
2004 - 2008 F150
Mar 13, 2010 08:49 AM
southbound35west
Jan 13, 2009 04:01 PM
kylem
Nov 28, 2004 03:26 PM
