Exploder Update
Old Sep 28, 2010 | 07:52 PM
Thomasm67's Avatar
Thomasm67
Exploder Update
Okay got the Xploder back today it runs somewhat. It won't shift into drive or OD might get to 20-25 mph but that is like at 2500 rpm any faster and the rpm's go up.And it stays in 2nd gear. Gonna change the filter and see what that does. I did put in some Lucas Transmission Conditioner and it hasn't helped. And yes it has plenty of Transmission fluid in it.
Old Sep 28, 2010 | 08:26 PM
Garden Spyder's Avatar
Garden Spyder
suppose they got the computer hooked back up to the tranny when they worked on the motor?
Old Sep 29, 2010 | 07:04 AM
Flip4ford's Avatar
Flip4ford
I sent you a PM. Sorry to hear that- I didn't think you owned the exploder any more?
Is the check engine light on? If so then there is a code.
There is the little vaccum regulator thingy on the side of the tranny - (shift modulator?) pull the vaccum line off of it and if fluid is leaking out then the modulator is bad. (cheap fix) (Passenger side Mid point on the tranny- down by the pan)
Sounds like we need to have a funeral for a dead tranny though. Save your money on a filter change- it won't do any good!
Old Sep 29, 2010 | 12:27 PM
husker's Avatar
husker
A4LD? If I remember right in the Sploders. Great tranny til they break.
Old Sep 29, 2010 | 01:20 PM
Flip4ford's Avatar
Flip4ford
Yep A4LD.......
Old Sep 30, 2010 | 08:24 PM
Thomasm67's Avatar
Thomasm67
Okay Good news vacume hose was off put it on replaced broken speed sensor on the Tcase speedo works fine and the tranny works as it is supposed to. Just need to fix few lil things that i can do.
Old Sep 30, 2010 | 08:37 PM
Hybris's Avatar
Hybris
I'm guess by little things you mean like brake upgrades and air lockers and air shock/bags right?
Either way good to hear that the Exploder is running better.
Old Sep 30, 2010 | 08:44 PM
Thomasm67's Avatar
Thomasm67
Yeah after 2 long yrs it finally runs but valve cover gaskets need replaced,Ball joints,oil changed a vacume hose is missing but i know which one it is. Cruise needs fixed lil stuff like that.
Old Oct 1, 2010 | 06:46 AM
Garden Spyder
now is this the slpoder you are keeping and driving? or the one you are giving away?
Old Oct 1, 2010 | 07:19 AM
Flip4ford's Avatar
Flip4ford
Good news.
I was wondering the same as Curtis.
Old Oct 1, 2010 | 08:15 PM
Thomasm67's Avatar
Thomasm67
She gets the Xploder that was deal i got the rear bumper on it have the old cracked leather seats out of it after we get the trash out of it and the carpet clean the good cloth seats go in.
Old Oct 2, 2010 | 08:24 PM
Thomasm67's Avatar
Thomasm67
Cleaned and vacumed the carpets replaced the leather seats with cloth had to switch the rails on the front seats so they could be bolted down. For some reason the rails on the cloth seats were to short the bolt holes did not line up.
