Hub nut size
Old Sep 28, 2010 | 05:02 PM
Bonanza35's Avatar
Bonanza35
Hub nut size
I have a 99 dually and have to change the emergency brakes. What size socket do I need to pull the spindles. It is a dana 6.25 I am told by ford. Please help if any Know. auto zone, ford and napa haven't been able to tell me, can you believe that, Ford! Thanks Chet
Old Sep 28, 2010 | 05:19 PM
clintbonnie's Avatar
clintbonnie
If it the same as my '99 dually, it measures 2 3/4" outside diameter at the 4 lugs, 1 9/16" on the shaft dia.. here is a pic.. I got mine at schucks/Oreileys... around $25..(PowerBuilt spindle nut # 648476)
Be sure to torque to the proper amount when re assembling.. Don't have the spec's right now..
Old Sep 28, 2010 | 09:46 PM
Blackbeltdually's Avatar
Blackbeltdually
When I did my parking brakes I bought my 4 lug spindle nut wrench for about $23.00 at the local CarQuest. Part number WIL W83008. Hope this helps.
Old Sep 29, 2010 | 12:37 AM
Bonanza35's Avatar
Bonanza35
Thank you Clintbonnie and Blackbeltdually I appreciate your quick response. I plan on doing this tomorrow I hope. I was suppost to leave for wyoming Thursday but will be lucky to get out by Sunday now. Is the tork 60psi? And why did your emergency brake go out, seals I guess I'll know soon here. I see no grease but they don't hold and pedal is strong. Chet
Old Sep 29, 2010 | 01:48 AM
clintbonnie
This is the method I used for re assembling the nut, etc..
When you re-install the hub nut, push in on the socket so the ratcheting parts of the hub nut don't engage and tighten to 70 lb/ft and then back it off 90º. Now retorque it to 18 lb/ft to 20lb/ft max.
Slide axle back in and torque the bolts to 77 lb/ft.
reptyls
Jan 25, 2015 06:35 PM
wahfulls
Modular V10 (6.8l)
Jan 12, 2013 11:49 PM
Whitey Ford
22
Feb 21, 2008 04:00 PM
mikedeason
Apr 2, 2007 10:38 AM
