5.8 engine swap questions
Old Sep 28, 2010 | 04:42 PM
nybronc's Avatar
nybronc
I have a 89 250 4x4 351, need a engine so , here's some options, a 94 bronco 5.8, use my fuel injection setup, or carb?, or a 98 351 lightning motor, again my injection or carb ?, I assume all will bolt up to my trans and acc., thanks for any input, I have the old low oil pressure, and knock on cold start. If the truck wasn't in such good shape ( I bought it in Utah) I'd just buy another truck, but no rust, and fully loaded Lariat model. ??? Let me hear some idea's out there, thanks, nybronc
Old Sep 28, 2010 | 05:01 PM
Conanski's Avatar
Conanski
For a the least amount of trouble swap in the '94 5.8, it's a direct swap with absolutely no changes necessary to your truck, just be sure to use the flywheel/flexplate that's in your truck now, bolt it in, and connect the existing wiring harness to the motor. The '94 motor has a bigger cam in it so you'll see power increases but not enough to upset the EFI system. It's a win-win.
P.S All EFI 5.8's use the same intake so you don't have to change anything on the donor motor(besides the flexplate) if it comes complete.
Old Sep 28, 2010 | 05:50 PM
nybronc's Avatar
nybronc
thanks Paul, would the 98 be a option as well, would my intake bolt to that also, someone mentioned to me the 5.8 engines were the same on the outside, just the internals and injection had changes.,
nybronc
Aug 12, 2013 01:06 PM
nybronc
Oct 4, 2010 05:59 PM
skychaney
May 29, 2003 12:22 AM
