The Super Duty trucks don't exhibit this issue nearly as often because there is a ton of intake system used as a buffer that absorbs the small amount of pressure fluctuation.
Unless you add an intercooler, you will never have a hope in getting the "problem" fixed.
Mine has never fluttered, before or after I installed my IC. I'd say fluttering is the exception, not the rule.
I'd suspect a pinched or kinked line somewhere. You might try 1/8" copper tubing if you're using plastic. It's available at most hardware stores and much easier to work with.
