Fluttering Boost Gauge?
Old Sep 27, 2010 | 08:32 PM
Brown Falcon's Avatar
Brown Falcon
Is that normal?
It's a Autometer Z series, and it's steady up to about 10psi and then above that it flutters pretty bad.
At WOT I was pegging a little over 30psi but it was fluttering a little above and below that so I was just taking the middle of it and calling it good...
Is there any way to fix this?
Old Sep 27, 2010 | 08:36 PM
chicagodragon's Avatar
chicagodragon
on the "t", the side going to the gauge should have a small hole, not as big as the map line. you may have to fill it with epoxy or something, then drill it.
Old Sep 27, 2010 | 08:44 PM
Talyn's Avatar
Talyn
I don't believe in t-ing the boost gauge into the Map line.
Just my .01$
Old Sep 27, 2010 | 09:32 PM
884x4broncoII's Avatar
884x4broncoII
my sunpro boost gauge does the same thing, will be currious if there is a fix for it.
Old Sep 28, 2010 | 06:07 AM
427 fordman's Avatar
427 fordman
what george said...
Old Sep 28, 2010 | 07:09 AM
Brown Falcon
Could be the way I T'd it. I'll have to try to put together a better way.
I have about 6" of extra map line coming off the T to a barbed fitting where my nylon line meets up with it.
Seems to work fine, just flutters at higher boost.
Old Sep 28, 2010 | 07:11 AM
Brown Falcon
Just my .01$
When I get a Intercooler installed I'll plumb it right into the spider... for now Just wanted something easy to install.
Old Sep 28, 2010 | 09:14 AM
superduty4x4's Avatar
superduty4x4
Brownie you might have a leak somewhere. Double check all your fittings (and teflon tape them if you didn't do it already). T'ing into the MAP line is fine... not the absolute best way to do it but it will be fine that way. I wouldn't worry too much about how you set your T up either that shouldn't matter. Also make sure that your tubing going to the gauge isn't kinked or pinched anywhere.
Old Sep 28, 2010 | 09:17 AM
Talyn's Avatar
Talyn
As george was saying, your trying to get a pressure reading, not a volume reading
With the larger hole, it tends to do that.
Dzl Jim had this problem as well.
Old Sep 28, 2010 | 10:14 AM
Brown Falcon
I teflon taped all of the threads, I'll double check the hose clamps when the rain lets up.
I may have tightened down the compression fitting on the gauge a little too much and pinched the line... I'll need to get another compression piece and re-do it to be sure.
Everything else is working great. EGT's look good. It's just crazy to me how much these trucks DON'T make boost just driving around normally. You really need to get into it to make any boost over 5psi or so.
Old Sep 28, 2010 | 01:14 PM
Talyn's Avatar
Talyn
Turbos only work under a load.
No load, no boost.
Thats why super chargers are quicker off the line.
But are only limited to engine RPM's.
So, super charger and turbo for the win!
So tempted to get one of these little car super chargers.
Old Sep 28, 2010 | 01:55 PM
strokin'_tatsch's Avatar
strokin'_tatsch
X2 on the pinched line. It could be pinched under the dash or somewhere near the guage too.
William, your just a hater. I got mine run in a Tee off the MAP line.. Don't hate, appreciate! LoL
Old Sep 28, 2010 | 02:01 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Normal condition.
There are a few forces at work here, but the main one is the lack of intake-side volume to act as a "buffer" for the combination of intake valve/manifold pressurization events and turbine drive speed variances due to exhaust pulse irregularities.
Old Sep 28, 2010 | 07:38 PM
desertrat64's Avatar
desertrat64
my gauge does the same thing and i have replaced all the connections and it still flutters over 10psi anyone know what it is
Old Sep 28, 2010 | 08:30 PM
Brown Falcon
I'm not too worried about it. It works, and I can still tell within a couple PSI where it is.
