White smoke...Head Gasket????
I have a 97 Expedition with a 5.4. Noticed white smoke that smells like antifreeze. I did a compression check on the motor. All cylinders range from 160 to 170. I then pressurized each cylinder with 100psi of air from my air compressor. I made sure each cylinder was at TDC while I did the check. I found that #5 cylinder would not hold the pressure and I could hear the coolant gurgling and my coolant reservoir and then it then it built up pressure. I now know that I have a bad head gasket but what I am puzzled about is that when I did my compression test, the #5 cylinder came in at 165 on my guage. I am now wondering if I should do a head job on my motor or drop in a used rebuild instead. I have 205,000 on it now. Any input would be appreciated to help me make up my mind.
You have good compression, your exhaust is white and smells like anti freeze and then you did a leak down test that showed #5 was leaking into the cooling system. It sure sounds like all you need is a head gasket replaced and while you're in there you should replace the timing set-up at the front as you have likely passed the time where they usually fail. That is the chain guides, chains and Tensioners.
Sprucegreen
1997-2006 Expedition & Navigator
06-05-2015 08:28 AM
Operator1
11-30-2014 12:02 PM
TexinCali
25
07-28-2014 06:22 PM
mytoys2037
06-17-2013 11:40 PM
