What is the best way to test the head gasket, I have always known that you pull the spark plugs on an engine (glow plugs in this case) and put a compression tester on each cylinder and turn it over. I found this video
Good pressues depends on load, temp and altitude.
But a gauge the goes beyond 15psi doent tell you you have bad head gaskets either.
Life is just not that simple.
This is something I'd be interested in learning too.
Sorry I don't have an answer to contribute to the discussion, but I do have a question that I think is relevant.....
What about the blue liquid testing devices that check for CO2 in the coolant system? Is that method accurate and reliable to determine head gasket issues?
https://www.ford-trucks.com/forums/1...9-08-03-a.html
Heres is some info on the subject. Failed head gaskets are misdiagnosed more then anything else, people uneducated in the process and lazy techs are the biggist issues in misdiagnosis.
If you're seeing occasional white smoke, you pull the EGR valve and it's dry. ECT/EOT deltas are within 5°-8°, no noticable or significant coolant loss or puking, and the blue liquid CO2 test shows positive, would it be conclusive to rule out egr cooler and assume head gaskets?
No but you could rule out the oil cooler as being bad. To rule out an egr cooler you would have to remove it, use block off plates and pressure test it.
