White smoke...Head Gasket????
Old 09-27-2010, 04:44 PM
doopeej's Avatar
doopeej
doopeej is offline
Unhappy White smoke...Head Gasket????
I have a 97 Expedition with a 5.4. Noticed white smoke that smells like antifreeze. I did a compression check on the motor. All cylinders range from 160 to 170. I then pressurized each cylinder with 100psi of air from my air compressor. I made sure each cylinder was at TDC while I did the check. I found that #5 cylinder would not hold the pressure and I could hear the coolant gurgling and my coolant reservoir and then it then it built up pressure. I now know that I have a bad head gasket but what I am puzzled about is that when I did my compression test, the #5 cylinder came in at 165 on my guage. I am now wondering if I should do a head job on my motor or drop in a used rebuild instead. I have 205,000 on it now. Any input would be appreciated to help me make up my mind.
Old 10-12-2010, 02:57 AM
eallanboggs's Avatar
eallanboggs
eallanboggs is offline
It's NOT white smoke. When water boils it turns to steam not smoke.
Old 10-12-2010, 08:23 AM
doopeej's Avatar
doopeej
doopeej is offline
It didn't look like it was just steam. It was a white smoke that stayed in the air for awhile. And it smelled like antifreeze.
Old 10-15-2010, 10:22 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
You have good compression, your exhaust is white and smells like anti freeze and then you did a leak down test that showed #5 was leaking into the cooling system. It sure sounds like all you need is a head gasket replaced and while you're in there you should replace the timing set-up at the front as you have likely passed the time where they usually fail. That is the chain guides, chains and Tensioners.
Sprucegreen
1997-2006 Expedition & Navigator
06-05-2015 08:28 AM
Operator1
11-30-2014 12:02 PM
Hellbringer
11-01-2014 12:00 PM
TexinCali
25
07-28-2014 06:22 PM
mytoys2037
06-17-2013 11:40 PM
Quick Reply: White smoke...Head Gasket????
