93 Ranger Battery
Old Sep 27, 2010 | 03:52 PM
mkrog's Avatar
mkrog
93 Ranger Battery
Put a new battery on my 93 Ranger 4.0 in March,about 4 weeks ago the battery was to weak to start the truck.I charge the battery for about 15 min. and it started.Yesterday it did it again,no crank just solenoid clicking.Battery had 12.59 volts,put on charger for 1/2 hr and it started.I went to the parts store and had every thing tested.Alt,battery,and starter draw all were good,parasitic draw was .02. What would be causing the battery to lose its punch?
I live in a small town and every place I go is about a mile or less away,could the short hops have any thing to do with the problem?My driving hasn't changed in the last 10 yrs but this problem just crop up.Any ideas?
Old Sep 27, 2010 | 08:19 PM
Franklin2's Avatar
Franklin2
If you have a voltmeter, lets go over again what the store checked. What is the voltage on the battery with the truck running?
Old Sep 27, 2010 | 10:42 PM
Gumbyagain's Avatar
Gumbyagain
Have you checked the battery cables for corrosion? Not just at the battery but at the solenoid & the grounds of the truck. I have found Odd issues on every known make & model from this. If the cable is corroded into the twisted wires under the insulation (especially if you find any split) change the cable & clean the mount points thoroughly. The auto parts stores seal a sealer that will coat it once you have a clean connection and don't over look rust either.
Old Sep 28, 2010 | 02:46 PM
mkrog's Avatar
mkrog
batt. voltage
14.70 no load-14.73 with lights on bright and fan on hi
Rollingscrapmetal
15
Jan 1, 2017 04:32 PM
lostman
36
Jul 3, 2015 02:29 PM
Forest Halleck
May 23, 2015 12:20 PM
bulldogchief
1983 - 2012 Ranger & B-Series
Oct 28, 2012 11:11 AM
