Sponsored by: Auxito
Spark plug blow-out question?
Old Sep 27, 2010 | 02:58 PM
tdpower's Avatar
tdpower
My friend has a 1998 or 1999 f150 and had a spark plug blow out. The shop he took it to is telling him the inserts are not very good and they usually get them back in a few
months with the same problem. The shop is recommending pulling both heads and taking them to a machine shop. Not really sure on that but the mechanic said it would be a permanent fix. They want to charge him $2800
to do both heads. I thought that sounded about right. Any suggestions? Thanks, I'll pass any feedback to my friend.
Old Sep 27, 2010 | 07:26 PM
galaxie641's Avatar
galaxie641
Take it to a different shop that will do the insert. When my first one popped the shop said they had only had 1 return again, of course I became #2 a few months back but it lasted over 2 years before it blew. I'd suspect this shop uses an inferior insert or just wants more money. For some comparison when my second plug blew I got a quote of $1700 to replace the head. The first time it blew it was accessible and cost under $300 to get an insert put in. Frankly for $2800 I'd be looking at a new/reman engine or at least new heads, Patriot performance still sells them for under $1500 a set. If he has a NPI engine then he'd need to upgrade the intake as well if he went with the patriot heads.
I'd also be interested in what a machine shop does to old heads to fix them permanently that doesn't involve putting 8 inserts in.
Old Sep 27, 2010 | 08:14 PM
tdpower's Avatar
tdpower
Thanks for the reply. I don't know that much about this. He was asking me for advice and shops to take it to. I don't usually take my truck to a shop unless it is a last resort. I was kind of thinking they were trying to take him for more money as well. I'm really not sure what the machine shop was going to do but I'll try to find out. He has about 200k on his truck and I thought that was a lot of money to put into the truck but if he can get another 100k out of it that would be a good deal.
Old Sep 27, 2010 | 10:53 PM
Hybris's Avatar
Hybris
I second the "Take it to a different shop" idea, I bet that for $2800 you could replace the heads maybe even with a fancy performance head and still have change leftover.
Old Sep 29, 2010 | 07:04 PM
smithbr06's Avatar
smithbr06
if you look online you can find the heads for the truck for $400 each.
plus the gaskets $50 and two or three hours and it can be done your self, it very simple if you have any experience at all. and also i replaced my whole engine for cheaper than $2000.00 used of course.
Old Sep 30, 2010 | 06:52 AM
olds72's Avatar
olds72
This repair is not that difficult to do. Although depending on which plug goes, it just gets more time consuming. I'm no technician/mechanic, just a hobbyist with a lot of tools and I did mine myself. I bought my helicoil set from NAPA and so far it's been in 2 years.
Old Oct 1, 2010 | 10:42 AM
kdson's Avatar
kdson
The first blow out I had was repaired by me with a borrowed Calvan 38900. Been holding for 2 years. The second was repaired with the Helicoil kit, lasted about 6 months. The Calvan kit was able to fix this one also, it's larger. I see no reason why it won't hold. The friend I originally borrowed the kit from did a dozen or so and he never had a return. Of course, I suspect some people fix them and trade the truck in. Thats the route I would go.
_Rick_
Jul 19, 2015 10:28 AM
towjoe42
Jan 11, 2013 06:37 PM
klr650goldwing
Modular V10 (6.8l)
Mar 15, 2011 11:24 PM
hgbyrne
1997 - 2003 F150
May 16, 2010 09:58 PM
GoldStarKimber
Modular V10 (6.8l)
17
Mar 1, 2004 12:58 PM
