Lug Bolt Replacement??
Old Sep 27, 2010 | 12:14 PM
cjuni's Avatar
cjuni
Cool Lug Bolt Replacement??
My question is regarding the replacement of the lug bolts. I broke a bolt off while replacing a tire. I took out the old bolt and now am unable to insert the new one from the back. It seems that the backing plate will not allow for a bolt to be inserted from the back.
Does anyone know if i have to remove the axle or just rotate the hub to a special area/spot in order to insert the new one?
Thanks in Advance
Old Sep 27, 2010 | 12:37 PM
davh's Avatar
davh
You can replace the lug without removing the axle. You need to grind 2 rivets from the rotor shield and turn to to a spot to the rear side of the axle. You also need to remove the 4 bolts on the square mounts to be able to turn the casting also. It is tedious but will allow you to change the lug without removal of the axle.
jvmcc
Oct 22, 2015 11:00 AM
Skip1970
Aug 17, 2015 02:19 AM
wit2003
Jun 17, 2015 03:11 PM
SAF
May 12, 2014 08:36 PM
fabieber
Jan 10, 2014 09:23 PM
