Engine swap ?'S
Old Sep 27, 2010 | 11:12 AM
j250hd's Avatar
j250hd
Engine swap ?'S
I am going to be swapping my blown engine for one that I bought that was allready out of a truck. What prevenitave maintanence/modifications would you do before putting the newer one in? All that is done mod wise is exhaust and intake. On a very tight budget.
Old Sep 27, 2010 | 11:33 AM
Brown Falcon's Avatar
Brown Falcon
Uppipe gaskets, Turbo O-rings, exhaust manifold gaskets if it needs it, oil pan gasket if it needs it.
That's all I can think of that aren't easy to do in the truck...
Old Sep 27, 2010 | 11:44 AM
triskadek's Avatar
triskadek
leaking dipstick tube
Old Sep 27, 2010 | 10:13 PM
quesey's Avatar
quesey
oil cooler orings
rear seal
as said b4 dipstick orings inside and outside the pan,.so theres new pan seal.tube of silicone will do the trick on it
Old Sep 28, 2010 | 09:54 AM
Brians97F250Crew's Avatar
Brians97F250Crew
while you got the engine out if you're going to put in a down pipe go ahead and bend the body seams while you got good room to swing a hammer.
Old Sep 28, 2010 | 10:08 AM
Brown Falcon
Hey Brian, your site isn't working for me...
Old Sep 28, 2010 | 12:22 PM
Midwest Dually's Avatar
Midwest Dually
That firewall mod is a lot easier with the engine out indeed! And take care of all those Turbo O-rings too.. its more of a PIA when in the engine compartment!
Old Sep 28, 2010 | 01:34 PM
Brians97F250Crew
Hmmm ... I'm at work and it's working from here. Not sure what's up with that.
