Gauge cluster and throttle problem
Old Sep 27, 2010 | 05:25 AM
MSD's Avatar
MSD
I have a 2002 F350 crew cab long bed. I stopped at a store yesterday and when I came out and started my truck I had no throttle and the gauge cluster was not working. It shifts and moves at idle speed but no throttle. The clock works but nothing in the cluster lights up.
I have owned this truck for about one and a half years now. Shortly after I bought it I purchased the Edge Evolution programmer and installed the towing program. I put in new batteries about 2 months ago.
Has anyone experienced this problem before? Any thoughts?
Thanks.
Old Sep 27, 2010 | 05:37 AM
Sheldon Plankton's Avatar
Sheldon Plankton
Thanks.
You have a blown underdash fuse, number 13 if I recall correctly. It's caused by chaffed insulation on the wire that goes to the overdrive control button on the end of the shifter handle. I had the exact same problem.
Old Sep 27, 2010 | 05:43 AM
Sheldon Plankton
Here's a photo of what I'm sure will prove to be your problem.
Old Sep 27, 2010 | 07:16 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Mines doing the same thing but blowing a #45 fuse (Excursion) and throwing a 221 code that I think is related to the throttle position sensor. Can you scan for codes? it's a soft code and doesn't always trip the light. There is a TSB out on it bulletin number 03B03. Tried to post a link but my stoopid computer said no.
Old Sep 27, 2010 | 07:27 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Here's the TSB although it's for an Excursion. 2002 FORD EXCURSION TSB's (technical service bulletins) Yours is a 2002 model like mine, might be worth looking into.
Old Sep 28, 2010 | 06:58 PM
MSD's Avatar
MSD
Sheldon,
I want to thank you for so quickly responding to my problem. You were right. But I had two blown fuses. The numbers didn't correspond to yours but the replacements fixed the problem. I just have to wait for the rain to stop long enough to install the new shift lever.
For everyone's information, my mechanic is an 18 year Ford veteran and he told me the wire cannot be repaired or spliced because there is resistance built into the wire.
Once again thank you to everyone for your responses.
teamo
May 31, 2017 05:36 PM
Gary Lewis
34
Mar 17, 2017 03:14 PM
Tiggie
Dec 22, 2016 11:50 AM
89er
Apr 1, 2016 12:03 AM
Gembone
17
Aug 1, 2013 05:55 PM
