Fun with TTB's.
Old Oct 6, 2010 | 12:16 PM
damac's Avatar
damac
Newb question here, I will have to tackle this in a few weeks. I already have the donor parts to go into our running truck.
Where am I going to safely jack up my truck so I can take out the old axle and leafsprings and install the donor?
I don't recall while taking a peak, where the heck I could safely do that
Old Oct 6, 2010 | 09:06 PM
tecgod13's Avatar
tecgod13
Jack it up like normal using the axle. Place jackstands under the frame.
Remove wheels and lower the axle until it is hanging free, then tension the jack slightly. Unbolt the leafsprings, lower axle completely.
You may have to use some blocks under the jackstands to get them high enough. Be careful!! Make sure the blocks are something solid that won't crumble or break, and use chocks on both sides of the rear axle.
Old Oct 6, 2010 | 10:32 PM
Sycostang67's Avatar
Sycostang67
Place your jackstands under the frame right behind the springs. You may as well get the bolts loose before you start jacking that way you aren't forcibly wrenching on it while it balanced on the stands. Since I wasn't swapping the leaf springs I was able to unbolt/remove everything except the pivot bolts before i started lifting the truck.
Old Oct 6, 2010 | 10:50 PM
mechelement's Avatar
mechelement
I needed to use another jack and a pry bar to get my pivot bushings to line up with the brackets in order to install the bolts. Those D50 springs seem to twist in torsion a bit, probably by design. I had the jackstands directly behind the front springs as previously mentioned. No issues.
Old Oct 6, 2010 | 10:55 PM
Sycostang67
Same here, we used a little 2 ton jack to push the pivot ends up into the brackets.
Old Oct 6, 2010 | 11:05 PM
mechelement
If you pop the diff off the back, do yourself a favor and reinstall it before doing the pivot bushings.
Sycostang67
Apr 16, 2014 11:18 PM
Sycostang67
Apr 25, 2013 10:08 PM
Sycostang67
Sep 21, 2010 10:16 PM
Sycostang67
15
May 17, 2010 02:23 AM
Sycostang67
20
Feb 28, 2010 02:26 PM
