360/390 intake
Old Feb 21, 2003 | 02:11 PM
DJ Rosa's Avatar
DJ Rosa
360/390 intake
Do they( ford ) actually make a 4 barell intake for a 360 or not??? Is there one out there anywhere.I want to upgrade but dont want to pay edelbrock.
Old Feb 21, 2003 | 02:43 PM
fordfan428's Avatar
fordfan428
360/390 intake
One that says that it is just for the 360, is that what you are asking?..I don't think so..But they do make them for FE family of which the 360 is a part of..You should be able to find one at any junk yard..
Old Feb 21, 2003 | 02:46 PM
DJ Rosa's Avatar
DJ Rosa
360/390 intake
yes ,but it will eliminate the hot water passage thru the manifold right.What is the after affect if I do change.
Old Feb 21, 2003 | 02:55 PM
fordfan428's Avatar
fordfan428
360/390 intake
I have had both the Ford cast iron and the edbk intakes (still do) on mine and have not had any problems..Just make sure you have help installing that heavy iron sucker..
Old Feb 21, 2003 | 05:55 PM
stephenw's Avatar
stephenw
360/390 intake
Ford never put a stock 4 bbl intake on a 360 engine. But just about any 4 bbl intake manifold from an FE will interchange onto the 360, and the coolant circulation is the same. If you go looking for a cast-iron model, the ones that have an "S" code cast onto the front intake runner are a little better than most. You will want to be sure that the ports on the manifold vs. your heads match up reasonably well tho, as some truck heads have small ports. It's not too much problem to be going from a small intake runner into a larger head port, but very poor practice to go from large to small.
That may be more than you wanted to know, but your question and follow-up were pretty open-ended. We on the forum can be a lot more helpful if you give us some specifics on your vehicle, engine and use!
Steve
Nick-1973-ford
Apr 10, 2019 11:51 PM
Shawnboylk
Mar 25, 2016 07:20 PM
dilmachender
Jul 24, 2014 05:36 AM
Austy
Sep 2, 2013 01:04 PM
karlsd
Nov 8, 2001 07:56 AM
